motortouring Posted October 16, 2017 Posted October 16, 2017 Hi everybody, I try to remove my rear wheel for a tyre change. According the manual I started with the left side 27 nut. It came loose a bit, but then the axle turned along and I cannot further remove the nut. Is there a stabndard trick to proceed?
motortouring Posted October 16, 2017 Author Posted October 16, 2017 Problem is clear now. My rear axle has a M18x1,5 thread were originally is the inbus (inside hexagon). That makes it a bit less standard to fix the axle. Solved now
luhbo Posted October 16, 2017 Posted October 16, 2017 So it probably once was seized. Maybe because of a jammed bearing? By the way, you have a nice avatar. I think it would look good on my white LMIII as well. Maybe with plasti-dip. Can we get this stuff around here?
motortouring Posted October 16, 2017 Author Posted October 16, 2017 Here are some historic pictures of the LM III of the avatar. More or less my lifetime project. I am now in the process of removing the lower frame and move the block and gearbox 10mm to the right. The 160/60 R18 rear wheel from Fast Pauls Daytona should then fit better. 1
luhbo Posted October 16, 2017 Posted October 16, 2017 nice:) You still have also the LMII visible in the shed?
motortouring Posted October 30, 2017 Author Posted October 30, 2017 nice:) You still have also the LMII visible in the shed? Sorry for the late reply, but yes, it is now almost ready for a new modification that allows a wider rear tyre.
