luhbo Posted October 19, 2017 Posted October 19, 2017 The lower is the fuel return. It's pressurised, min. 3bar, so don't turn the ignition on until you have this hose clamp tight again. If you already have, then surely it was an interesting experience anyway Those pumps do deliver. 1
docc Posted October 19, 2017 Posted October 19, 2017 That’s the high pressure fuel return to the regulator. Best to move that clamp onto the regulator’s connector and tighten it appropriately. 1
vents Posted October 23, 2017 Author Posted October 23, 2017 Got in a 200 mile ride this weekend and the starting issues were gone . Not sure what fixed the problem but I cleaned up and lubed the bullet connectors , cleaned terminals at the starter and the battery . Thanks for the suggestions guys .
docc Posted October 23, 2017 Posted October 23, 2017 Got in a 200 mile ride this weekend and the starting issues were gone . Not sure what fixed the problem but I cleaned up and lubed the bullet connectors , cleaned terminals at the starter and the battery . Thanks for the suggestions guys . Original post: " . . . sometimes when I hit the starter button then engine spins normally and sometimes I get absolutely nothing ." That is so characteristic of the "bullet connectors" from the Clutch Switch. Cleaning, tightening, and sealing the battery terminals (with petroleum jelly/ Vaseline®) is important/ critical as well! Glad to hear you are rolling! + = 1
fubar guzzi Posted October 26, 2017 Posted October 26, 2017 Mine does the same thing I too will follow advise as given thanks
footgoose Posted October 26, 2017 Posted October 26, 2017 Mine does the same thing I too will follow advise as given thanks apparently that will do you no good. (fubar) but welcome to the forum anyway.
