Everything for $95 plus shipping to USA. Spares for 2002 LeMans. PayPal okay. From Olympia, WA
2 pair valve cover gaskets
2 sump gaskets
1 oil filter
2 shift lever return springs
1 throttle cable
1 Brembo 11mm rear master cylinder rebuild kit
1 Brembo rear caliper rebuild kit (for P32B)
2 exhaust gaskets
2 NGK spark plug caps
1 set rear brake pads
2 fork seal washers
2 transmission/bevel drive plug washers
3 transmission output shaft O rings
2002 LeMans parts book
If gstallons doesn't buy the kit, I'll take it. That looks like a good value, and I just broke a shift spring.
Perform the other shift spring mod . I own a Racecraft spring & if mine breaks while sitting I am going to fix mine the other way .
P.M. me the particulars & I will Paypal this afternoon
what's a Racecraft spring? My "alternative" mod is working well, but when I go back in there, I will stiffen up the spring.
 I think Racecraft was the company . It is some brans that is stronger / better than stock .
Bugtarget , I am trying to reasch you you complete the transaction . Please PM me so I can pay you .
You should probably take his email address down, not good to have that out on the interweb, especially if he doesn't know.
Agreed.
I broke it up.
If you haven't boxed it up , {please} send Scud the shift spring .
No need. I have a few.
