Tomchri Posted July 14, 2020 Posted July 14, 2020 Good idea from Jim there,, how can I say so now. You will hear it when the side cover finds home. Cheers tom. 1
4corsa Posted July 15, 2020 Posted July 15, 2020 ...exactly what I did a couple weeks ago. When i did the first dry run, they were off by just an 1/8" or so and needed a little adjusting and refitting. Glad I didn't have the sealant on at that point.
docc Posted July 15, 2020 Posted July 15, 2020 Very soon I intend to install the Chuck-Made/Scud Spring and compare to a factory replacement spring with about 64,000 miles/ 100.000 km on it. This replaced one that broke in my warranty replacement gearbox after about 27,000 miles. Here is the conundrum. I have the "other two" factory replacement springs. Should I swap in these other two springs for the ones in the warranty gearbox that have about 90,000 miles/ 145.000 km on them?
po18guy Posted July 16, 2020 Posted July 16, 2020 What is your intent for those other two transmissions? To sell with the caveat attached, sure. For yourself? Time-bomb trannies do not a touring gentleman make. MG, Harper's or someone who has the ability and desire to wind these springs up should have them listed in their online parts lists. Relying leaning on the tried and true forum members gets a little wearing on them.
docc Posted July 16, 2020 Posted July 16, 2020 I only have the warranty gearbox (installed since ~27,000 miles). Moto Guzzi took the original back. Right before they made the recall. If any Guzzi parts supplier would take any interest in stocking these springs, I suspect that would be Gordon at MG Cycle. Perhaps he could even send some to Stein-Dinse since I'm pretty sure they have a relationship. Curious to see how the other two springs compare to new ones. The shift lever is failing to spring back up more often. I seem to recall one of the other springs aids that function as well as the "pawl spring" in question (?)
footgoose Posted July 16, 2020 Posted July 16, 2020 1 hour ago, docc said: I only have the warranty gearbox (installed since ~27,000 miles). Moto Guzzi took the original back. Right before they made the recall. If any Guzzi parts supplier would take any interest in stocking these springs, I suspect that would be Gordon at MG Cycle. Perhaps he could even send some to Stein-Dinse since I'm pretty sure they have a relationship. Curious to see how the other two springs compare to new ones. The shift lever is failing to spring back up more often. I seem to recall one of the other springs aids that function as well as the "pawl spring" in question (?) the pawl spring only puts tension on the arm, for positive engagement. Not sure which spring aids the shift lever. I suspect one of "those others" 1
Lucky Phil Posted July 16, 2020 Posted July 16, 2020 1 hour ago, footgoose said: the pawl spring only puts tension on the arm, for positive engagement. Not sure which spring aids the shift lever. I suspect one of "those others" The shift lever return spring. Ciao 1 1
Steve S Posted July 16, 2020 Posted July 16, 2020 Message sent to Scud, I need more springs in the UK if available
Tom in Virginia Posted August 1, 2020 Posted August 1, 2020 Broke side cover down, this is what I found. Chuck and Scudd's spring installed. Everything checks out, hand worked the edge where the spring contacted selector so its rounded edge. Really excited to get her back on the road, been missing this bike since it went down. Boss on selector checked out at 14.91 mm. Guess the 2002 with 2500 miles will get same treatment when it arrives. 1
Tom in Virginia Posted August 1, 2020 Posted August 1, 2020 (edited) Oh, by the way, based on RTV job on the selector box cover, I could safely say this "CHUCK/SCUD spring" is at least the 3rd spring to go into this bike, to include original. I imagine the guy I bought it from had problems around 18,000 miles and had to pay the shop to fix. Once that was done (paying Northern VA shop prices) he was likely motivated to deal on his asking price. Just my guess. I will forever love this bike, it is the most fun to ride of all the bikes I had. I'd be willing to put another 10 springs in it if I had to, but that will be highly unlikely with the perfection that you guys have engineered/manufactured here. Edited August 1, 2020 by Tom in Virginia editorial misspellings, grammar 4
po18guy Posted August 2, 2020 Posted August 2, 2020 Is that marinara sauce in the trans??? Or just a red-blooded Guzzi? 2
Steve S Posted August 2, 2020 Posted August 2, 2020 Springs arrived in the UK and fitted, thanks Scud 2
gstallons Posted August 2, 2020 Posted August 2, 2020 11 hours ago, po18guy said: Is that marinara sauce in the trans??? Or just a red-blooded Guzzi? My Greenie looked like that . After five days of running for 10 minutes and oil changes every day , it cleared up .
Tom in Virginia Posted August 2, 2020 Posted August 2, 2020 13 hours ago, po18guy said: Is that marinara sauce in the trans??? Or just a red-blooded Guzzi? You guessed it, a little bit of both. Red Line Marinara seasoned with Italian Gootsie blood. 1
po18guy Posted August 3, 2020 Posted August 3, 2020 19 hours ago, Tom in Virginia said: You guessed it, a little bit of both. Red Line Marinara seasoned with Italian Gootsie blood. That blood-red beauty should not be hidden. I wonder if a clear Lexan cover could be made??? 1 1
