PJPR01 Posted November 20, 2017 Posted November 20, 2017 A side benefit (tongue in cheek) of having taken off the tank to do a few repairs on filter/fuel hose etc...is checking everything else on the bike and finding stuff to fix! So far all else is good, but I notice that the steering damper (part # 01530230) has quite a bit of free play in it at the center mounting point. Tried tightening up the hex bolt there at the center mounting point, but to no avail, so I'm assuming that I need either a new bracket or washer/filler to tighten this up, and hopefully not needing to replace the actual steering damper, which feels smooth and with no catches from side to side. Have others had success sourcing an equivalent mount or have you done some other fix here, as this particular part is not sold separately by Guzzi. Feels like an important item to fix so the mounting bolt doesn't break, as in that case, for sure I'll have to buy the whole damper. Mille grazie...
stewgnu Posted November 20, 2017 Posted November 20, 2017 Is this at the rose joint? If so i think it’s meant to move about as the steering rotates
docc Posted November 20, 2017 Posted November 20, 2017 As stewgnu says, there should be play in the pivot. But not in the mount, itself. I'll have to review to see if the steering damper is mentioned in the Tank Off Maintenance Checklist.
PJPR01 Posted November 20, 2017 Author Posted November 20, 2017 If by Rose joint, you mean the center anchoring joint vs. the end mount, then yes...that's where the movement is. I see about a 1/16 of an inch movement, you can see the frame of the steering damper be flush and then rotate open a bit. The "free play" is inside that circular mount where the hex bolt goes thru. There seems to be a little spider screw there as well, but on mine at least it does not appear to be adjustable, and my hex bolt is as tight as it can get, so I'm guessing there's looseness in the washer/mechanism inside that circular mount. If that's normal...great, but it feels sloppy to me.
docc Posted November 20, 2017 Posted November 20, 2017 Yeah, they look to flop around, but that is normal. Mine actually came loose at the mount (lock nut) once. I can't remember if I LocTited it . . .
PJPR01 Posted November 20, 2017 Author Posted November 20, 2017 Super...thanks docc!! One less item to replace then! Much appreciated.
docc Posted November 20, 2017 Posted November 20, 2017 Most common failure with the Bitubo damper is leaking oil. I have heard of people rebuilding them, but I replaced mine with a Japanese made Shindy.
PJPR01 Posted November 20, 2017 Author Posted November 20, 2017 Most common failure with the Bitubo damper is leaking oil. I have heard of people rebuilding them, but I replaced mine with a Japanese made Shindy. Interesting...how did you figure out which is the right one for the V11? Looking at their site, I just see dampers for Harley and other Japanese bikes.
swooshdave Posted November 20, 2017 Posted November 20, 2017 Does it move around like this? Should be a previous post of mine with the same question.
GuzziMoto Posted November 20, 2017 Posted November 20, 2017 Most common failure with the Bitubo damper is leaking oil. I have heard of people rebuilding them, but I replaced mine with a Japanese made Shindy. Interesting...how did you figure out which is the right one for the V11? Looking at their site, I just see dampers for Harley and other Japanese bikes. They are listed by stroke and overall length. You need a replacement that can at least match the stroke of the stock unit, and the length of the shaft over all should be about the same.
docc Posted November 20, 2017 Posted November 20, 2017 Mine moves like dave’s. Even the Shindy. Moto International in Seattle spec’d The Shindy as a Bitubo alternative
PJPR01 Posted November 20, 2017 Author Posted November 20, 2017 Swoosh...yes...moves about the same amount, a tad less on mine. What did you end up doing to fix it, if anything, or just accept it as normal as docc has said? Thanks Guzzimoto...will take a look. Replacement OEM runs about $320...so I'll compare price on the Shindy. I'm guessing then that this "free play" is for fork compression to allow a bit of angle change while still allowing the damper to function linearly.
Scud Posted November 20, 2017 Posted November 20, 2017 I used the Shindy on my LeMans for a while. It lives on the Greenie now. Same type of back and forth play. It should be tight side to side. Got the part number from a past post of Docc's. @Docc - if you feel motivated, maybe you could add that damper to our encyclopedia of compatible parts. I recall it being only about $120.00.
PJPR01 Posted November 20, 2017 Author Posted November 20, 2017 At that price...it's a steal, would be great as a future reference in case a replacement is needed. Good thing is that the side to side motion is clean and with zero catches...nice and smooth. Looks like I'm all good then here...thanks all for the timely feedback.
swooshdave Posted November 21, 2017 Posted November 21, 2017 I don't recall if I did anything. I know the damper works (although I keep it wound out). http://www.v11lemans.com/forums/index.php?showtopic=19822&p=219758
