PJPR01 Posted December 11, 2017 Share Posted December 11, 2017 Well... 2 steps forward, 1 step back...Scura still leaking fuel. Replaced the fuel line with Scud's upgraded item, new fuel filter, new petcock (original one was full of dirt and gunk), and put it all back together, and the damn thing still leaks, so now I believe I'll have to replace the famous Flange into which the petcock screws into as that appears to be the true source of the leak. Bloody impossible to find this part, have checked at MG, Harpers, Moto International and Gutsibits, no luck! Found it finally at Stein Dinse (Danke sehr!)...but I'm wondering before I place the order if anyone has a US source for this part # since the shipping costs from Germany are more than the cost of the flange itself! https://www.stein-dinse.biz/Complete-partlist/Unsorted/Flansch-Tank-V11::6671.html Part # 01101830 Thanks all! Link to comment Share on other sites More sharing options...
swooshdave Posted December 11, 2017 Share Posted December 11, 2017 Is the flange broken or the gasket leaking? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
PJPR01 Posted December 11, 2017 Author Share Posted December 11, 2017 The flange itself is not broken, but it's leaking from where the petcock screws onto the flange, so the threaded part of the flange. I don't see it leaking at the gasket on the tank...at least not at the moment! Link to comment Share on other sites More sharing options...
Chuck Posted December 11, 2017 Share Posted December 11, 2017 There's probably a gasket on the end of the flange.. Link to comment Share on other sites More sharing options...
PJPR01 Posted December 11, 2017 Author Share Posted December 11, 2017 There is a hard opaque plastic ring in there on the end of the shaft in the flange and not easily removed by the way. It is smaller in diameter than the black O-rings, I did tuck a new O-ring in there and it fits snugly inside the flange around the opaque plastic one and a bit deeper, but it does consume 1 thread's depth of the locking nut. I may try it again w/o the new O-ring and see if that allows me to snug it up a bit further. I'm guessing that using Teflon tape here on the threads is not a great idea, anything else I could add to the threads to get a better seal? Link to comment Share on other sites More sharing options...
czakky Posted December 11, 2017 Share Posted December 11, 2017 There are fuel resistant thread sealants. Check your local auto parts store. Link to comment Share on other sites More sharing options...
Chuck Posted December 12, 2017 Share Posted December 12, 2017 Yes, there are.. comma but if the plastic ring doesn't seal, it will still leak around it. (I think) Link to comment Share on other sites More sharing options...
Scud Posted December 12, 2017 Share Posted December 12, 2017 Can't you find a used one on e-bay or a bike salvage place? Link to comment Share on other sites More sharing options...
PJPR01 Posted December 12, 2017 Author Share Posted December 12, 2017 Can't you find a used one on e-bay or a bike salvage place? Thanks...No luck yet there Scud...the only ones on Ebay come from the Netherlands (are new also) and have the same freight charge as buying it from Stein Dinse. I haven't gone the salvage route just yet...will play with the gasket situation a bit further and then decide on buying it from Germany..may just have to add a few more items to the order to justify the freight charge. I think you're right Chuck...it might just be this plastic ring...anyway, a chance to get creative before I order a new part (probably makes sense to buy two of them anyway) as I'm sure that over the years the other side will need to be replaced at some point as well. The only silver lining I have found so far is that since this part is as difficult to find as hen's teeth, it must mean that it fails very infrequently...so once fixed or replaced should last me a long time! Philosophy lesson for the day! Link to comment Share on other sites More sharing options...
swooshdave Posted December 12, 2017 Share Posted December 12, 2017 Is it off the bike and can you show the flange, o-ring and plastic ring relationship? Link to comment Share on other sites More sharing options...
PJPR01 Posted December 12, 2017 Author Share Posted December 12, 2017 Is it off the bike and can you show the flange, o-ring and plastic ring relationship? Hi Dave... It's back on the bike at the moment, so I'll have to get to the project after the holidays and will take some pics when I get back if I am unable to sort it by then. Appreciate all the suggestions...something for me to ponder while enjoying some desert/mountain vacations over the next couple of weeks. Link to comment Share on other sites More sharing options...
docc Posted December 12, 2017 Share Posted December 12, 2017 . . . while enjoying some desert/mountain vacations over the next couple of weeks. Now I'm havin' trouble feelin' sorry for ya. Ya had me goin' there, for a while . . . 1 Link to comment Share on other sites More sharing options...
PJPR01 Posted December 13, 2017 Author Share Posted December 13, 2017 Sorry I meant to say... While huddling over a bonfire in minus 30 degree weather with only a thin layer of clothing, gloves with no fingers and only one tin of Tuna and a half package of year old ramen to last me a week!!! 1 Link to comment Share on other sites More sharing options...
