stewgnu Posted January 7, 2018 Posted January 7, 2018 Hi All, can someone tell me how to remove the angled nipple from the top of the master cylinder? I thought maybe it’d pull out? Cheers Stew
Steve S Posted January 7, 2018 Posted January 7, 2018 Hi Stew I didn't know the answer to this so I went and dug out a spare one and with a bit of persuasion and wd40 the plastic bit pulls out of the rubber, used 2 screw drivers 1 each side
stewgnu Posted January 7, 2018 Author Posted January 7, 2018 Ah! Cheers Steve, thought i’d ask first as i was reluctant to force it. Are they available to get separately do you know- mine is damaged.
stewgnu Posted January 7, 2018 Author Posted January 7, 2018 Or alternatively, can i buy your old one?
MartyNZ Posted January 7, 2018 Posted January 7, 2018 You can buy the bits at https://www.stein-dinse.biz/Complete-partlist/Unsorted/Plastic-angle-90-GRAD-hand-and-rear-master-cylinder::227475.html I bought one from Moto International, along with the rebuild kit 110436292. . BTW, brake fluid or brake cylinder assembly lubricant is best for lubricating brake hydraulic system parts. Scud did an excellent test which shows that WD-40 swells brake system rubber parts. http://www.v11lemans.com/forums/index.php?showtopic=19330 1
Steve S Posted January 9, 2018 Posted January 9, 2018 Send me your address and I'll send you one no charge
stewgnu Posted January 9, 2018 Author Posted January 9, 2018 Steve you’re a gent! I sourced one off’v ebay though- which arrived today!
