r3datom9 Posted January 19, 2018 Posted January 19, 2018 Hi Gents, I recently picked up another V11 and after a couple of months I just noticed that it is surging a little at highway speeds. Has a PC3 and custom tune, but don't think that would make a difference. This might be happening at lower speeds too but I haven't noticed it. Any input would be appreciated. Thanks all!
docc Posted January 19, 2018 Posted January 19, 2018 Unplug the PC and perform a "Decent Tune-up." Gives you a baseline to decide if there is anything really "wrong." Examine the relays. If the last relay (Position#5) is not rated for high current, running issues can ensue. Install a full set of High Current OMRON.
r3datom9 Posted January 20, 2018 Author Posted January 20, 2018 Thanks guys! I bet I have a cracked rubber intake boot. One of them popped off a few weeks back, I went to up the bike and it ran like crap. Shaking all over the place, I bet I damaged it putting it back on. Will have to check if the spare ones are any good still. The relays are all GEI if I remember correctly, not quite as good as OMRON versions but they should suffice.
JBBenson Posted January 20, 2018 Posted January 20, 2018 Unplug the PC and perform a "Decent Tune-up." Gives you a baseline to decide if there is anything really "wrong." Surging is classic symptom of "TPS base-setting is out-of-spec". 1
r3datom9 Posted January 20, 2018 Author Posted January 20, 2018 It is minor, but definitely there. I am going to check the boots first. How difficult is the throttle body sync? Do I need to do a full sync or just adjust the tps correctly? Thanks all
docc Posted January 20, 2018 Posted January 20, 2018 So . . . every step in the Tune-up affects the others. They are all equally important. If you leave one out, all bets are off. The "Decent Tune-up" is a compendium of many peoples' efforts over the years and years. It is worth learning and doing. As I recall, it is six basic steps including setting the CO Fuel Trim with guzzidiag, baselining the TPS with a quality voltmeter, adjusting the valves, balancing the throttle bodies , and drinking beer. I could have one or two of those steps out of order . . . These are the two most straight-forward starting points to baseline any V11. Cost? About a hundred bucks US ($75 for the cables and about $20 for the relays. Add maybe a hundred bucks for a balancing tool like TwinMax or whatever. The PC is obsolete. Your throttle body rubber blew because the throttle bodies are out of balance and the rest of the parameters are out of tune. GEI are under rated and will not suffice. They fail. They are not up to the current demands in more than one location (#5, #2, and possibly #1). This is well established. The fact that under-rated relays contribute to running (and other issues) has been established unequivocally.
r3datom9 Posted January 20, 2018 Author Posted January 20, 2018 Thanks for the thorough explanation Docc! I will get these parts ordered and tackle the project in the next few weeks.
docc Posted January 20, 2018 Posted January 20, 2018 It is really do-able! If the Decent Tune-up and adequate relays do not solve the issues, you are in the right place! These guys take care of each other and our V11 ! 1
r3datom9 Posted January 20, 2018 Author Posted January 20, 2018 Thanks for the vote of confidence! I am well trained wrencher, former Coast Guard mechanic, I think I got this. Just need to find the right carb tuner, there seems to be much debate on the interweb forums. Imagine that! Hahaha
docc Posted January 20, 2018 Posted January 20, 2018 I remember being told by a respected Guzzi-guy that the digital devices would not hold up to the accuracy of mercury sticks (which I still use). Over the luscious loins of a Coppa Italia, motowfo and I put this to rest. The TwinMax will do the job.
r3datom9 Posted January 20, 2018 Author Posted January 20, 2018 Gonna go with the tune-up regardless. I am not sure the last time it was done. I'm keeping the PC, it was dyno tuned after all the internal work and came with a custom map. Seems foolish to do it all over again. The previous owner was a great guy, but I don't know what maintenance he did and it is possible it hasn't been done since the bike was last put together by Moto International. I think it has only had 5k or so on it since. How long does it usually take to notice the bike needs a tune/sync.
JBBenson Posted January 20, 2018 Posted January 20, 2018 Get a breakout harness for the wiring going to the TPS. Search this site for “breakout” and “Casper’s electronics” Makes the setting of the TPS WAY easier the first time, and will make it WAY easier to re-check periodically.... 1
docc Posted January 20, 2018 Posted January 20, 2018 The service interval is 6,000 miles/ 10.000 km. New plugs, valve adjustment, throttle body balance. Once the CO Fuel trim is set, that's it. Generally, same for the TPS baseline, yet there are some vagueries that can cause it to drift over time/miles/hours of operation. I have found that performing a good tune-up even at 4,000 miles is noticeable. Much like tuning a musical instrument before each playing.
docc Posted January 20, 2018 Posted January 20, 2018 Get a breakout harness for the wiring going to the TPS. Search this site for “breakout” and “Casper’s electronics” Makes the setting of the TPS WAY easier the first time, and will make it WAY easier to re-check periodically.... Cables here: http://www.v11lemans.com/forums/index.php?showtopic=19612
