Scud Posted March 15, 2018 Posted March 15, 2018 Haha... the Staburags ain't goin' anywhere. I wonder if it could also be used on the V11 transmission input hub? That's one of the recommended spots on the BMW bricks.
docc Posted March 15, 2018 Author Posted March 15, 2018 I recall discovering that the BMW gearbox drive benefits from lubrication. I was afraid to put anything on mine for fear of splattering the clutch surfaces. Any lube that slings off the gearbox input hub goes straight to the friction plates . . .
Pressureangle Posted March 15, 2018 Posted March 15, 2018 This is pro stuff, similar to the aforementioned Wurth product but much less expensive. Made specifically for open, dry environment lube. https://www.grainger.com/product/1HBK7?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!166591268592!!!g!392080792495!&ef_id=Wo9WZAAAAFvEa0N7:20180315004547:s 1
Lucky Phil Posted March 15, 2018 Posted March 15, 2018 Here is the "judicious" application of Klüber Staburags with a toothbrush, and careful clean-up including "Q-tips." Thats all you need on there docc. Also a light application of moly spray instead of the grease works fine. I apply it by spraying it onto a plastic lid or some other clean surface and applying with a 1/2" stiff short bristle paint brush in locations where I dont want any overspray. Or sprayed directly out of the can when it doesnt matter about the over spray. Let the solvents flash off for a nice dry, even thin coat and assemble. Works well on clutch splines. Stays where its supposed to and doesnt attract cluch plate dust. Ciao 1
docc Posted March 15, 2018 Author Posted March 15, 2018 Here is the "judicious" application of Klüber Staburags with a toothbrush, and careful clean-up including "Q-tips." Thats all you need on there docc. Also a light application of moly spray instead of the grease works fine. I apply it by spraying it onto a plastic lid or some other clean surface and applying with a 1/2" stiff short bristle paint brush in locations where I dont want any overspray. Or sprayed directly out of the can when it doesnt matter about the over spray. Let the solvents flash off for a nice even thin coat and assemble.Works well on clutch splines. Stays where its supposed to and doesnt attract cluch plate dust. Ciao Makes me hopeful. what I've been doing at every tire change for over 100,000 miles has been good lubrication, but I am weary of the mess.
docc Posted March 15, 2018 Author Posted March 15, 2018 This is pro stuff, similar to the aforementioned Wurth product but much less expensive. Made specifically for open, dry environment lube. https://www.grainger.com/product/1HBK7?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!166591268592!!!g!392080792495!&ef_id=Wo9WZAAAAFvEa0N7:20180315004547:s And for "Wire Rope", like our throttle cables?
Chuck Posted March 15, 2018 Posted March 15, 2018 That *does* look like good stuff. I tried a witches brew of dry moly and chain lube on a clutch spline. After a few hundred miles (don't ask) I looked again, and it was gone.
Pressureangle Posted March 15, 2018 Posted March 15, 2018 This is pro stuff, similar to the aforementioned Wurth product but much less expensive. Made specifically for open, dry environment lube. https://www.grainger.com/product/1HBK7?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!166591268592!!!g!392080792495!&ef_id=Wo9WZAAAAFvEa0N7:20180315004547:s And for "Wire Rope", like our throttle cables? NO! Wire rope like cables on cranes and winches. The stuff is thick and heavy so it won't fling off, and sticks like heck. 1
docc Posted March 15, 2018 Author Posted March 15, 2018 I would have bought the Würth SIG 3000 if it had been available. They do look to be quite different products. Anything as white as the Klüber makes me think "lithium grease." Is that what it likely is? I have an inspection interval (for a rear tire) in about a thousand miles. Not sure what to expect . . . just no slung-out nasty mess!
gstallons Posted March 18, 2018 Posted March 18, 2018 Docc , use the Dry Film Graphite spray I sent you . Clean off everything til there is no oil on the surfaces and spray a coat on the splines and let dry . Repeat a few times and you're set . 1
GILPUTT Posted March 21, 2018 Posted March 21, 2018 You guys just use the Sig 3000 exclusively on the splines? What about for the grease fittings back there, same stuff? Thanks
czakky Posted March 22, 2018 Posted March 22, 2018 I’d say any quality grease would be fine for the U-Joints. I don’t have experience with the Sig 3000 but it looks a bit overkill on the u-joints. 2
Chuck Posted March 22, 2018 Posted March 22, 2018 All I've ever used in u joints is Mobil 1 synthetic grease. It's what is in my grease gun.. 1
GILPUTT Posted March 22, 2018 Posted March 22, 2018 I’d say any quality grease would be fine for the U-Joints. I don’t have experience with the Sig 3000 but it looks a bit overkill on the u-joints. Thanks
