Rocketron Posted May 7, 2018 Share Posted May 7, 2018 Does anyone know the specs on the single rear shock and any known interchanges ? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
docc Posted May 8, 2018 Share Posted May 8, 2018 I have an original Sachs-Boge "on display." I can take some measurements for you. What are you looking for? Link to comment Share on other sites More sharing options...
Lucky Phil Posted May 8, 2018 Share Posted May 8, 2018 Does anyone know the specs on the single rear shock and any known interchanges ? Sent from my iPhone using Tapatalk I have 4 bikes, 2 fitted with Wilbers shocks (GSXR-1000 and the V11 sport) and 2 fitted with Ohlins ( 1198 with the high spect TTX and the 1000ss with the production Ohlins) If your looking for a V11 replacement I can recommend the Wilbers and they taylor it to you needs. From memory the std rear shock is 310mm long, cant remember the sprig rate though. Ciao Link to comment Share on other sites More sharing options...
Rocketron Posted May 9, 2018 Author Share Posted May 9, 2018 I have an original Sachs-Boge "on display." I can take some measurements for you. What are you looking for? Thanks! Compressed length and extended length along with uncompressed length of spring. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
docc Posted May 9, 2018 Share Posted May 9, 2018 I’ll have see if I can get the spring off . . . Link to comment Share on other sites More sharing options...
Scud Posted May 9, 2018 Share Posted May 9, 2018 You might prefer the specs on the Ohlins shock, which causes the bike to sit a bit higher in the back. I think the spec sheets are somewhere in the fileshare section of this site. Manufacturers, such as Wilbers, Penske, and Hyperpro, can make a shock to the original or Ohlins specs. Link to comment Share on other sites More sharing options...
JBBenson Posted May 9, 2018 Share Posted May 9, 2018 Stock Sachs on the V11 Sport is 278mm center of eyelet to center of eyelet. I replaced it with a Hyperpro 460 adjustable @ 290mm with +/- 5mm. Link to comment Share on other sites More sharing options...
