So I jumped on the bike this morning and started with a loud chattering noise. When i let the clutch out it went away. Noticed that when I pulled the clutch in it came back and the Tacho goes to zero even though the revs are still up. Took it for a ride up the street and everything is working just this verrrrrrry loud noise when i pull the clutch in. The bike has had the clutch and flywheel replaced with the heavier one from a "california" i think from memory as a precausion from a previous owner to avoid the Scura flywheel problem. I've had Mike Rich valves, pistons and cam installed.
Any one had this before? Thanks in advance
Tim
Ok,  so for the next person it was the starter button stuck on. I wish every problem in life was that easy :homer:
