Cabernet Posted June 10, 2018 Posted June 10, 2018 Someone on here posted they'd had a pawl spring failure. They also posted they were able to still get a gear change by braking heavily before changing. Having a spring go after less than 6000 miles I gave it a go. A bit of a hit and miss affair, but I was able to go from 2nd to 5th where I stayed until near home, then dropped back to 4th for the last urban 2miles. Spring is out now and ready for a new one. So thanks for sharing the technic. Sent from my G3121 using Tapatalk 2
Chuck Posted June 10, 2018 Posted June 10, 2018 Attaboy. If you don't have the Scud spring, I'd recommend it. What year V11 btw?
Cabernet Posted June 10, 2018 Author Posted June 10, 2018 I believe it to be 2002 mascarading as a 2003. Yep I read something on that a while back. Got a link to it perchance? Fuel pump outside the tank and formerly black face clocks. Now red. Sent from my G3121 using Tapatalk
Scud Posted June 10, 2018 Posted June 10, 2018 That was me with the hard-brake-to-shift technique. Glad it helped you get home. When you have the pre-selector out, you can see that the spring pushes the arm forward (and a broken spring allows it to flop backward). Therefore, hard braking can get the arm to flop forward into place for one shift. I still have a little box of the new "unbreakable" springs. Send me PM if you need one. US$10 per spring. Add US$5 shipping to US. Add US$15 shipping outside US.
Cabernet Posted June 10, 2018 Author Posted June 10, 2018 Yes, I got the logic in your previous post. It does work after a fashion. Sent from my G3121 using Tapatalk
Scud Posted June 10, 2018 Posted June 10, 2018 Yes, I got the logic in your previous post. It does work after a fashion. ...just enough to sneak in a few shifts and get home. Nothing you'd want to rely on beyond that. Really - it's quite rewarding to know that the idea helped somebody. Thanks for mentioning it.
