swooshdave Posted June 15, 2018 Share Posted June 15, 2018 https://uploads.tapatalk-cdn.com/20180615/cd7d77e5ce09d5410f586d7521203cdd.heic Is there suppose to be a bolt here? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
docc Posted June 15, 2018 Share Posted June 15, 2018 Well, yeah, buddy! That is the main front (sub)frame connection to the "stressed member" engine . . . Good find!! Link to comment Share on other sites More sharing options...
Chuck Posted June 16, 2018 Share Posted June 16, 2018 Holy Crap?? You are kidding, right? Link to comment Share on other sites More sharing options...
JRD Posted June 16, 2018 Share Posted June 16, 2018 Did you notice a little extra vibration, not to mention that frame flex while you were riding down the road? Link to comment Share on other sites More sharing options...
footgoose Posted June 16, 2018 Share Posted June 16, 2018 Dave, when I did my clutch swap, I noticed mine gone in the same spot. No idea how long I went without but there was no problems I could tell. The hole was perfectly lined up. scary tho. PM your add and I'll send you one. (if you can wait that long:) Link to comment Share on other sites More sharing options...
swooshdave Posted June 16, 2018 Author Share Posted June 16, 2018 Did you notice a little extra vibration, not to mention that frame flex while you were riding down the road? No frame flex that I could tell. There is a tiny bit of vibration but let’s be real, it’s a Guzzi. Link to comment Share on other sites More sharing options...
swooshdave Posted June 16, 2018 Author Share Posted June 16, 2018 Dave, when I did my clutch swap, I noticed mine gone in the same spot. No idea how long I went without but there was no problems I could tell. The hole was perfectly lined up. scary tho. PM your add and I'll send you one. (if you can wait that long:) That is very generous. Before you do that can you tell me the dimensions of the bolt? I can’t exactly take out the other one to measure it. If I can’t readily find one locally I’ll take you up on your offer. Link to comment Share on other sites More sharing options...
footgoose Posted June 16, 2018 Share Posted June 16, 2018 35mm M12? Not too sure about the M but it measures about 11.6mm with calipers. I guess that’s a 12. Full thread Allen. Shnoor washer Link to comment Share on other sites More sharing options...
swooshdave Posted June 16, 2018 Author Share Posted June 16, 2018 35mm M12? Not too sure about the M but it measures about 11.6mm with calipers. I guess that’s a 12. Full thread Allen. Shnoor washer Course thread? 1.75 pitch? Step one is to see if I can steal one off the 850-T... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
docc Posted June 16, 2018 Share Posted June 16, 2018 The Tonti frame of the 850T is nothing the same . . . Link to comment Share on other sites More sharing options...
docc Posted June 16, 2018 Share Posted June 16, 2018 MotoInternational lists it (doesn't mean they have it), but no details on fastener size/ pitch: GU98612635 Two US dollars, fifty US cents [i have long used a method of LocTite-ing any fastener found missing from my single or my twin. . .] Link to comment Share on other sites More sharing options...
footgoose Posted June 16, 2018 Share Posted June 16, 2018 Coarse yes, sorry I don’t have a gauge Link to comment Share on other sites More sharing options...
swooshdave Posted June 16, 2018 Author Share Posted June 16, 2018 The Tonti frame of the 850T is nothing the same . . . How much money you want to put on that? https://uploads.tapatalk-cdn.com/20180616/114add7ca3cb7d76ded1f3a8c50f9746.heic So I first pulled of the frame bolt from the 850-T but since it has the engine guards it was too long, but it was the right size. Next step was to dig through the spare parts that came with the 850-T and bingo, the original bolts! And guess what? Yup. Perfect size! No washer but some loctite and it will be good for now. So go check these on your bike if you haven’t for a while... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
swooshdave Posted June 16, 2018 Author Share Posted June 16, 2018 Coarse yes, sorry I don’t have a gauge Actually I believe it’s fine. 1.25 instead of 1.75. I do have a gauge. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LowRyter Posted June 16, 2018 Share Posted June 16, 2018 better check ...... whew. Link to comment Share on other sites More sharing options...
