Just picked up a 2000 V11 sport. Removed the previous owners pipe wrap to discover the caps on the exhaust headers are missing. Look to be lambda sensor holes in other parts of the world. Have tried a M10 1.5 pitch bolt but thread doesn't seem to match. Anyone know if this is 1.5 pitch thread?
If you have thread pitch gauges you could check that way.
Might be 10x1.75(10mm xfine)
Turns out to be an M10-1 pitch.  A 1/8- IP (pipe thread is very very close and if using a tapered pipe thread will work) Problem solved
