Solid, Marty! Thank you!
So, it appears the map on this fellow's V11 is the factory "Titanio".
So is there a map repository for the V11 Sports or not?
From what I can tell there are only two maps? Is that right?
Two V11 factory maps? That is my understanding as well.
Those would be the two depicted in Posts #1(Titanium) and #2.
Well, that's not very impressive...  :mellow:
And, here, I was relieved it was not more complicated than that.
However, am I right that any map can be altered (over-written) and, if the "ID" is not changed, seeing the changes can only be found examining individual values in the tables?
Do us all a favor, if you write over a V11 map, change the ID. :nerd::luigi:
Hi Docc
This is not a must.
Only if Meinolf cares about and changes the identification digits on the map. There can also be loaded a substantially changed map to the ECU which is not recognisible in Guzzidiag.
Just wanted to say in full disclosure I am the guy DOCC is helping with the 04 V11 Lemans with the infamous light throttle hiccup issues and questions related to the map currently loaded in my bike.  Thx for all input.
