I need a bit of help on how to select neutral with the gearbox selector plate removed. I changed out gearbox selector spring but first time things did not go back properly for me. I could only select first to third gear so back in I went. However I didn't get neutral selected properly before removing the selector plate and now I cannot get the plate reinstalled. Initially even using the clutch I could not move the bike but now I have properly selected a gear, which one I don't know. Whats the best way to find neutral so I can zip it up again?
Rob
Rob
Hi Rob,
There are a couple of pictures here:
https://www.v11lemans.com/forums/index.php?showtopic=20117&page=2&do=findComment&comment=227185
https://www.v11lemans.com/forums/index.php?showtopic=19547&page=4&do=findComment&comment=218290
Check that the rear wheel spins freely, and you should be good.
Thanks Marty,
I must have been trying too hard last time, all it needed was a little movement of one of the selectors and now the wheel spins freely. I need to pick up a couple of replacement circlips tomorrow and we are away laughing.
Rob
This is neutral:
