swooshdave Posted March 13, 2019 Posted March 13, 2019 That does make sense. I believe the tanks are nylon, which does attract water. Am I correct on the tank material?
Lucky Phil Posted March 13, 2019 Posted March 13, 2019 That does make sense. I believe the tanks are nylon, which does attract water. Am I correct on the tank material? Yep. Ciao
Walterg Posted March 17, 2019 Author Posted March 17, 2019 So our nylon tanks attract water and as the material absorbs water it swells and causes the tank to expand. But how do the bubbles develop ? With vinyl wrap I meant wrapping the tank with a wrapping foil. Not Plastidip. Something like this
Admin Jaap Posted March 17, 2019 Posted March 17, 2019 Hi Walter, I've never heard of anyone on this forum wrapping a nylon V11 tank. So all replies are probably based on theories. It's on you to try first and let us all know how it goes Being an old fart , my choice would be painting. I had mine painted black by a professional painter.
Lucky Phil Posted March 17, 2019 Posted March 17, 2019 32 minutes ago, Walterg said: So our nylon tanks attract water and as the material absorbs water it swells and causes the tank to expand. But how do the bubbles develop ? With vinyl wrap I meant wrapping the tank with a wrapping foil. Not Plastidip. Something like this I suspect the bubbles are water that leaches all the way through the tank material but I honestly dont know definitively. Why dont you prick a bubble and see if any fluid comes out. If the paint bubbles and you wrap over the paint then obviously you will have the wrap bubbling as well. You cant wrap over an unpainted tank because the only way to get the paint off a plastic tank in reality is to media blast them and thats what I've had to do in the past. Then the tank surface is too rough to wrap. My main question with the wrap and I've seen a bit of it done on youtube and its amazing stuff and the guys are skilled is, is it fuel proof from the point of view of spillage during refueling and the inevitable constant exposure to slight fuel vapors around the filler cap fitting etc. Ciao
