al_roethlisberger Posted November 6, 2018 Posted November 6, 2018 Interesting: https://realgaskets.com/ USE CORK? GET REAL! Real Gaskets that is… Real Gaskets Tennessee is a manufacturer of silicone Rubber valve cover gaskets for Continental, Franklin & Lycoming aircraft engines in addition to Continental, Jacobs, Lycoming, Pratt & Whitney and Wright radial piston aircraft engines. We even manufacture silicone valve cover gaskets to fit your Ford, GM, Mopar, and Porsche automobile engine and rocker box gaskets for BMW, Harley-Davidson, Suzuki, BSA, Ducati, Moto Guzzi, Norton, Triumph, Saab, VW, and most all other motorcycle engines. These silicone rubber gaskets, which are made from aerospace mechanical grade AMS silicone, are 100% reusable, designed to withstand temperatures up to 400°F, and to last the life of the engine. If you are tired of oil leaks, then a silicone rubber valve cover gasket is the only way to go and Real Gaskets Tennessee is the only place you can get ‘THE ORIGINAL’ silicone rubber gasket. Thanks for stopping by! Aircraft engine support is no joke, so I wonder how well these work for our application. Anyone have any experience with these products for sump or valve cover gaskets? https://realgaskets.com/product-category/motorcycle/moto-guzzi/
LowRyter Posted November 6, 2018 Posted November 6, 2018 I've killed three of them under the valve covers on my two Guzzis. No doubt it's an installer's problems since I've killed plenty of paper valve cover gaskets too.
Tomchri Posted November 6, 2018 Posted November 6, 2018 Original Toyota sealer, just a tiny bit ( blue wrapping, has to be the black content inside ) on all my gaskets, even cheap ones. No need for overtightning head covers etc. Ooops I recieved parts for Cessna to my V11 today Cheers tom.
Chuck Posted November 6, 2018 Posted November 6, 2018 Real gaskets stop leaks on aircraft engines with their flimsy stamped valve covers. I've used them for years. The screws holding them down not only don't need to be tight.. they *shouldn't* be tight. Just snug em up.
docc Posted November 6, 2018 Posted November 6, 2018 I feel like, someday, I'll have to change the original ( ) valve cover gaskets on my Sport . . . I did, finally, change the sump gasket, but it wasn't really leaking. Yet, the OEM V11 gaskets are not actually paper (certainly not "cork"), are they? What are they, then?
not-fishing Posted November 7, 2018 Posted November 7, 2018 Didn't work on my son's V50. Didn't work on my Griso. I like the Green paper gaskets but I've just learned to live with a little drop once in a while when it gets close to valve adjustment time.
gstallons Posted November 7, 2018 Posted November 7, 2018 Hmmmm . Have you applied Hylomar to the gaskets ?
Lucky Phil Posted November 7, 2018 Posted November 7, 2018 These are the best......Valpollini, Pete Roper sent me a set and they are perfect. Some kind of metal hybrid gasket with a coating. Dont get too carried away with aircraft piston engine technology as a lot of it is from the dark ages. Conti and lycomings use cotton thread to seal the case joint for goodness sake. Ciao
Chuck Posted November 7, 2018 Posted November 7, 2018 These are the best......Valpollini, Pete Roper sent me a set and they are perfect. Some kind of metal hybrid gasket with a coating. Dont get too carried away with aircraft piston engine technology as a lot of it is from the dark ages. Conti and lycomings use cotton thread to seal the case joint for goodness sake. Ciao Gotcha.. it's silk thread. Red is hard to find..
GuzziMoto Posted November 7, 2018 Posted November 7, 2018 I have silicone gaskets from Real Gaskets on both a V11 and a Griso. Both work really well. I also have a similar gasket on the differentials of our Jeep. I like them. You do need to be careful about not over tightening them. If you over tighten you can destroy the gasket. I have not personally done so, but I have heard from others that have. But if you are capable of not over tightening them they work brilliantly.
Chuck Posted November 7, 2018 Posted November 7, 2018 I have silicone gaskets from Real Gaskets on both a V11 and a Griso. Both work really well. I also have a similar gasket on the differentials of our Jeep. I like them. You do need to be careful about not over tightening them. If you over tighten you can destroy the gasket. I have not personally done so, but I have heard from others that have. But if you are capable of not over tightening them they work brilliantly. Yep. Real gaskets stop leaks on aircraft engines with their flimsy stamped valve covers. I've used them for years. The screws holding them down not only don't need to be tight.. they *shouldn't* be tight. Just snug em up.
Lucky Phil Posted November 7, 2018 Posted November 7, 2018 These are the best......Valpollini, Pete Roper sent me a set and they are perfect. Some kind of metal hybrid gasket with a coating. Dont get too carried away with aircraft piston engine technology as a lot of it is from the dark ages. Conti and lycomings use cotton thread to seal the case joint for goodness sake. Ciao Gotcha.. it's silk thread. Red is hard to find.. I was counting on you Chuck to fill in the fine details:) I learned a long time ago that I dint need to be very smart to survive, just had to know smart people. Ciao 2
leroysch Posted November 8, 2018 Posted November 8, 2018 Have used these in both applications without any issues on my V11, including re-use. No drips, seepage, etc. Did buy a torque wrench capable of the in-lbs they spec.
