swooshdave Posted November 13, 2018 Posted November 13, 2018 I think you can buy LEDs rated for 12v out of the box but another alternative is these. They are prewired and have a built in resistor and are relatively cheap. I don’t have a specific use... yet. Pack of 50 in different colors were about $8. Haobase 50pcs Mixed Colour 5mm LEDs Pre Wired Light 12V 20cm Bulb https://www.amazon.com/dp/B01DZIRPM4/ref=cm_sw_r_cp_api_pvV6BbYDCD0H1 Sent from my iPhone using Tapatalk 1
Kiwi_Roy Posted November 13, 2018 Posted November 13, 2018 I used something like that, one on each relay 87 contact to chassis, this was a great troubleshooting aid. You soon get used to the light show and immediately recognize when something is amiss. Mount them by drilling a hole in the relay base although you could also mount them on a little plate beside the relays. Just pop each 87 contact out and solder the small wire to it. [image by docc_edit] 1
LowRyter Posted November 13, 2018 Posted November 13, 2018 Oh Blinding Light...Oh Light That Blinds...I Cannot See...Look Out For Me!
