rich888 Posted April 24, 2019 Posted April 24, 2019 Anyone know the original manufacturer of the ECU plug, harness side? IAW15M ECU. I assume Aptiv/Delphi of some type?
68C Posted April 25, 2019 Posted April 25, 2019 This website has the socket that is a part of the ECU, they may be able to help you with the plug. You need one if building a MyEcu. I just cut up an old ebay V11 l.oom. https://www.te.com/global-en/product-6437288-6.html
emry Posted April 25, 2019 Posted April 25, 2019 AMP Superseal 1.0. Make sure you get the correct keying, there are 3 different ones if I recall. Corsa-Technic 1
rich888 Posted April 25, 2019 Author Posted April 25, 2019 48 minutes ago, emry said: AMP Superseal 1.0. Make sure you get the correct keying, there are 3 different ones if I recall. Corsa-Technic Great thanks. I was looking at TE interconnect superseal 1.0 I have a spare ECU that I want to plug into to develop my scangauge, instead of balancing everything on the bike the garage!
Kiwi_Roy Posted May 5, 2019 Posted May 5, 2019 When I built a MyEcu kit for my VII Sport I took the plug off my existing ECU, I had a power commander as well so I wired it directly to the old ECU board and fitted them both in a metal box as a spare ECU
