Rolf Halvorsen Posted June 12, 2019 Posted June 12, 2019 I remember reading that that sensor should measure around 650-700 ohms between + and + pin (3pins version). But I have forgotten where I read this. Can anyone help me? Would like to copy that article. Rolf
antmanbee Posted June 12, 2019 Posted June 12, 2019 That is correct. I found that when searching for cross reference and some of the parts stated the specifications.
Kiwi_Roy Posted June 13, 2019 Posted June 13, 2019 https://dpguzzi.com/efiman.pdf The values in this manual still apply to the smaller ECU If you read through this it gives a good understanding of how an injection system works. One thing that doesn't apply is the vacuum hose on the pressure regulator on the later bikes it's open to atmosphere and the ECU compensates for barometric pressure. 1
Rolf Halvorsen Posted June 14, 2019 Author Posted June 14, 2019 Thank you. This document is the best I have seen - ever. I am soooo pleased. Rolf
