  • 4 weeks later...
Hi Dave,
I don't know if the hardware of the ECUs used is exactly the same, the additional identifier (16Mxxx) on the ECU label would help in answering this.
The code used in the Duc BINs is similar or identical (given the hardware of the bike is the same) regardless of the bike's make. Marelli uses a code library approach, many code sections can be found in all ECUs (P8, 16M, 15M, 5AM and even 7SM, though this one uses an inline coding technique).
Cheers
Meinolf
