luhbo Posted July 6, 2019 Posted July 6, 2019 My problems were heavy emc interference from crappy plug caps. Between 3 and 4K it was really bad, had to stay below or above. The gap was 1.2 mm. I reduced it to rather zero what made a big improvement. The history behind it: I had changed the plug caps (to the crappy ones), as a result the MyEcu quit working. Swapping this against a Marelli ecu seemed to work, but only until the engine had warmed up. From here on I was on the wrong track. Anyway, a weak, or as in my case, a too noisy phase signal may totally spoil your bike experience Good thing is: the sensor itself is rather robust. Properly mounted it's not a part to be afraid of.
Kiwi_Roy Posted May 29, 2021 Posted May 29, 2021 I find the easiest way to gap the sensor is to stick something like a glob of JB Weld on the tip, bolt it in place, wait for the JBW to set up then remove it again and measure the blob with a pair of callipers. 1
Chuck Posted May 29, 2021 Posted May 29, 2021 When I was going through the Centauro, I used the depth measurement end on the calipers. I would no doubt permanently affix the sensor to the flywheel using the JB method. 1
Tomchri Posted May 29, 2021 Author Posted May 29, 2021 A simple perfect tool for Phase sensor distance. Cheers Tom Sent fra min SM-A505FN via Tapatalk 8
gstallons Posted June 1, 2021 Posted June 1, 2021 '.030'' is the recommended air gap . You should have an assortment of gaskets to get the right gap . 2
gstallons Posted July 28, 2024 Posted July 28, 2024 On 5/29/2021 at 3:50 PM, Tomchri said: A simple perfect tool for Phase sensor distance. Cheers Tom Sent fra min SM-A505FN via Tapatalk Does this look right ?
Tomchri Posted July 28, 2024 Author Posted July 28, 2024 25 minutes ago, gstallons said: Does this look right ? YES 1
swooshdave Posted August 12, 2024 Posted August 12, 2024 Where do you get that tool? Let me guess, it’s called a cam sensor gauge?
Tomchri Posted August 12, 2024 Author Posted August 12, 2024 8 minutes ago, swooshdave said: Where do you get that tool? Let me guess, it’s called a cam sensor gauge? Easily made in an afternoon with a lathe, as it said back in the days on Hooker headers. I did find it much easyer than with the caliper. Cheers Tom.
swooshdave Posted August 12, 2024 Posted August 12, 2024 4 minutes ago, Tomchri said: Easily made in an afternoon with a lathe, as it said back in the days on Hooker headers. I did find it much easyer than with the caliper. Cheers Tom. https://www.etoolcart.com/88800031-sensor-depth-gauge.html This price has to be a joke, it’s cheaper to buy a lathe.
Tomchri Posted August 12, 2024 Author Posted August 12, 2024 9 minutes ago, swooshdave said: https://www.etoolcart.com/88800031-sensor-depth-gauge.html This price has to be a joke, it’s cheaper to buy a lathe. BIG JOKE, sold a few 19.99. Cheers Tom.
