Tomchri Posted July 9, 2019 Posted July 9, 2019 Is it certain my left injector is a little clogged ?? She is running all good, from idling too full speed. That said, my Greenie is like a bomb, compared to the Rosso Corsa. I have a feeling there is another cam in the Greenie. . I have 8liter of moonshine,,,, from way back, so will feed her with some of the jungle juice AFC is one turn out,,,, thought I had a small exhaust leak at the head,, that could cause heat, no not that. Anyone with this experience? Cheers tom.
footgoose Posted July 9, 2019 Posted July 9, 2019 TB balance port nipple cap missing/rotted? In any case I would try the "spray something flammable" on the intake rubber bits method, to see if any air leaks
Tomchri Posted July 9, 2019 Author Posted July 9, 2019 On 7/9/2019 at 9:38 PM, footgoose said: TB balance port nipple cap missing/rotted? In any case I would try the "spray something flammable" on the intake rubber bits method, to see if any air leaks Expand Intake rubbers less than a year old. No nipples , just bolts on the balance holes, and no misfiring when running. cheers tom.
gstallons Posted July 10, 2019 Posted July 10, 2019 If you have an IR camera or temp gun , run your bike down the road & back . Check temps at the exhaust pipes and see how close the temps are . I have temp guns and an IR camera .The camera is GREAT !
Lucky Phil Posted July 10, 2019 Posted July 10, 2019 How do you know its running lean on one cylinder? Ciao
Tomchri Posted July 10, 2019 Author Posted July 10, 2019 On 7/10/2019 at 2:08 AM, Lucky Phil said: How do you know its running lean on one cylinder? Ciao Expand When taking of the headers, looking into left head, all very white ( light color ) and right head is black compared to the left. Will try to borrow a Fluke temp gun today like GS mentioned. Cheers tom.
gstallons Posted July 10, 2019 Posted July 10, 2019 You have it disassembled , when you get it together , start it up and use a mechanic's stethoscope and see if both injectors "click" the same ?
Tomchri Posted July 10, 2019 Author Posted July 10, 2019 Thanks for advices, will report back. cheers tom.
Lucky Phil Posted July 10, 2019 Posted July 10, 2019 On 7/10/2019 at 9:03 AM, gstallons said: You have it disassembled , when you get it together , start it up and use a mechanic's stethoscope and see if both injectors "click" the same ? Expand Good luck with that, the injector pulse duration at idle is probably only a couple of milliseconds. A Ducati 888 is 12.43 milliseconds at 7000 rpm peak torque. Ciao
luhbo Posted July 10, 2019 Posted July 10, 2019 After 150.000 km I noticed the same picture on my bike: one header black, the other one white. I pulled the injectors, activated the pump, then applied 12V to the injectors for 10 seconds and measured what they delivered. The difference was significant. I don't think it was a matter of clogging, in fact it's more likely that one was badly worn (nozzle hole to big) or that they weren't matched right from the beginning. Anyway, I swapped them against a different and much better matched pair, had both ports the same colour - and felt exactly no difference on the road. Even the fuel consumption was the same.
Tomchri Posted July 10, 2019 Author Posted July 10, 2019 On 7/10/2019 at 12:38 PM, luhbo said: After 150.000 km I noticed the same picture on my bike: one header black, the other one white. I pulled the injectors, activated the pump, then applied 12V to the injectors for 10 seconds and measured what they delivered. The difference was significant. I don't think it was a matter of clogging, in fact it's more likely that one was badly worn (nozzle hole to big) or that they weren't matched right from the beginning. Anyway, I swapped them against a different and much better matched pair, had both ports the same colour - and felt exactly no difference on the road. Even the fuel consumption was the same.Mine has 56000km, and she might have been like this for a while. Dont want to burn a valve or. My jungle juice will probably not cure this. Another Injektor seems more likely. Thanks for the inputs. Cheers tom. Sent fra min SM-G903F via Tapatalk
luhbo Posted July 10, 2019 Posted July 10, 2019 The light one looks right, I would want it even lighter, going for white. The other one is sooty, surely not ok. Directly behind the outlet valve I wouldn't want any carbon residues at all. Being an outlet valve should be no fun. It also looks as if the gasket on the right cylinder was blowing 1
Tomchri Posted July 10, 2019 Author Posted July 10, 2019 On 7/10/2019 at 3:43 PM, luhbo said: The light one looks right, I would want it even lighter, going for white. The other one is sooty, surely not ok. Directly behind the outlet valve I wouldn't want any carbon residues at all. Being an outlet valve should be no fun. It also looks as if the gasket on the right cylinder was blowing Expand Just finished swapping one injector and out for a test, she runs the same way. New exhaust gaskets. Checked the balance, perfect. I'm probably in for changing the sooty one to Gentle gentle getting those tiny bolts out. Now it's IPA time. cheers tom
MartyNZ Posted July 10, 2019 Posted July 10, 2019 If you want to clean and backflush your injectors, I could post a little kit to you. (so long as you send it back). The kit is a bit crude, but allows you to flush forward and reverse through the injectors. It can't help if you have worn or mismatched injectors, as mentioned by Luhbo. Those injector retaining screws were fitted with locktite so I drilled off the heads and then got new screws. https://www.v11lemans.com/forums/index.php?/topic/18805-brand-new-scura/&do=findComment&comment=215317 https://www.v11lemans.com/forums/index.php?/topic/20282-fuel-injector-cleaner-yea-or-nea/&do=findComment&comment=229694 1
Tomchri Posted July 10, 2019 Author Posted July 10, 2019 On 7/10/2019 at 6:46 PM, MartyNZ said: If you want to clean and backflush your injectors, I could post a little kit to you. (so long as you send it back). The kit is a bit crude, but allows you to flush forward and reverse through the injectors. It can't help if you have worn or mismatched injectors, as mentioned by Luhbo. Those injector retaining screws were fitted with locktite so I drilled off the heads and then got new screws. https://www.v11lemans.com/forums/index.php?/topic/18805-brand-new-scura/&do=findComment&comment=215317 https://www.v11lemans.com/forums/index.php?/topic/20282-fuel-injector-cleaner-yea-or-nea/&do=findComment&comment=229694 Expand Another Guzzisty friendship story. Yes please. The colors on the pictures doesn't show correct, lighting issues. I thought she was to lean, she is more white than showing. My mistake, right injector needs help. And if possible to do it when it's installed, good. Didnt show a brand name on the rattle can ? Name and adr next? Cheers tom.
