Hello,
My V11 won't start despite I have new relais and have taken off all connectors and made the massa cable as clean as possible. So far so good, until I noticed that turning the steering to the right is starting the start engine. And I can even force that by holding the starting button- nothing- then turning and while turning  about 15gr  it it is starting. I have done that 10 times over. So I think I have a broken wire or bad connection. Is there anybody with the same experience who can tell me what cause is mostly the main reason ?
If your cables just sticks -hangs out of your ignition lock , could be a little solder job and some fresh vaseline or similar for the copper plate.  When finished I would leave a disent amount  of play for the cables and fastnen to the ingnition lock.
 Cheers tom.
This would be the "bullet" connectors on the left side of the bike. There's a pic towards the bottom of this thread.
Check this as well
Ken
