Hi Doc, you know so much so hopefully you have another hint too.  I asked the question a little while ago on the forum. The V11 where the meters are planned has the problem of starting when turning the steer to the right. I think it is a broken wire or bad contact. So when I place the meters it is a good moment to repair this unhappiness. It is helpful to know some places that often causes this problem. Are you known with some suspected places? Thanks again,Dirk
^^^^^^ There are a pair of bullet connectors on the left side of the steering head that become loose/corroded.
Had the same issue where the bike would lose power when turning the bars ('Stuur' for us dutchies ;)).
In my case it was caused by a lose wire inside of the ignition switch similar to what Kiwi_roy discribes in his topic
You could also check the bullet connectors near the front left of the frame that run to the clutch switch, as mentioned by Chuck.
--EDIT--
Just found this older topic discussing how to check the bullet connectors, it could help you diagnose if the connectors are causing your issue
