swooshdave Posted August 12, 2019 Posted August 12, 2019 Forgive me, Father, I can't recall the last time I rode my Greenie. I've gotten distracted with other toys. The Norton Commando Interstate got here and I've been riding it. The 750 Commando started up after an engine rebuild. I'm just about done fitting the fairing and it'll go out for some break-in rides. And I just traded by Corvette for a new project (emphasis: PROJECT) But I am keeping the Greenie on the charger just in case! 2 1
footgoose Posted August 12, 2019 Posted August 12, 2019 The Guzzi will take you back no matter how often you cheat on her, or with what. 1
swooshdave Posted August 12, 2019 Author Posted August 12, 2019 2 hours ago, footgoose said: The Guzzi will take you back no matter how often you cheat on her, or with what. That's good because if you cheat on an English vehicle there will be repercussions. 1
Nihontochicken Posted August 12, 2019 Posted August 12, 2019 Good to see your first ride starting off from the sidewalk! Given my steep driveway with no turnaround room leading down to a steep, high crown road with fall line at a right angle, I have to back out my V11 and turn it 90 degrees to put it on the sidewalk to get started. It's rewarding to see someone do similar, if not regularly or for the same reason.
swooshdave Posted August 12, 2019 Author Posted August 12, 2019 1 hour ago, Nihontochicken said: Good to see your first ride starting off from the sidewalk! Given my steep driveway with no turnaround room leading down to a steep, high crown road with fall line at a right angle, I have to back out my V11 and turn it 90 degrees to put it on the sidewalk to get started. It's rewarding to see someone do similar, if not regularly or for the same reason. I’m lucky the driveway isn’t steeper. It’s already more than what I like. I’m not sure I could push the V11 Sport up it.
