Hi again
could some refresh my memory as to the ac voltage on the 2 yellow wires from the stator.
trying to determine why my charge light is on
thanks
Andy
What is the voltage at the battery key off? At idle ? At a couple thousand RPM?
Seems to me that is should be around 40V AC at around 4K rpm.
Expand
Yep,  Workshop Manual says 15 volts AC at 1000 rpm,  40vAC @ 4000, 80 vAC @ 6000.
If it puts out 15v @ 1k & 40v @ 4k , i will trust the next # of output !
  On 8/18/2019 at 8:49 PM, andy york said:
Hi again
thanks
Andy
Expand
Maybe we can get together , My light will NOT come on ?
The regulator is the common failure. My light only comes on depending on the phases of the moon.
Expand
LOL.    I wasn't aware that mine worked.In a previous regulator install, the directions said the charge light would be in operative.
beats me....but its on now.  Need to find a Shinnding reg or whatever its called. Like to try something different.
beats me....but its on now.  Need to find a Shinn  ding reg or whatever its called. Like to try something different.
Expand
Only done about 4000miles with my  upgrades,    Shindengen 847 on 2 bikes.     My stator and regulator seems to have a healty temp, compared to before.   And I run without the 30amp fuse    :D.
Cheers tom.
  On 8/22/2019 at 10:16 AM, luhbo said:
Cutting out this 30A fuse is dangerous.
Expand
Now you made me wondering .  And I just put in a fuse.    It was just a test to see if everything was working without the fuse,   and it was  ?
 Cheers tom.
With the fuse open the regulator won't work, means won't charge. With the fuse solidly bridged (what I understand under "running it without a fuse") you go a rather high risk of fire in whatever form. Because then you have your mighty Odyssey directly connected either to the regulator or, in case of a shorted cable, directly to the frame or the engine etc.
