Tr500 Posted August 26, 2019 Posted August 26, 2019 Coe eu56 showing on my Griso year 2006 also red triangular light and service. How do I rectify this. Manual/ small thick book not informative enough. I have tried putting in code and then deleting, but still no joy. Oil level o.k. . Any advice please
docc Posted August 27, 2019 Posted August 27, 2019 Others who know these newer models better should be along with good solutions . . . (I did change your topic title to get some more attention on the matter . . .)
nobleswood Posted August 28, 2019 Posted August 28, 2019 Try going to Grisoghetto.com & doing a search there 1
pete roper Posted August 28, 2019 Posted August 28, 2019 ECU56 is the speedo sensor. Has it been wet where you are or have you recently washed the bike? Early sensors were prone to water intrusion at the join between the cable and the 'Block'. If you remove it and dry it with a hairdryer and then seal around the join with silastic it may solve the issue. If not buy a new one. They aren't terrifically spendy. Diagnostic code for Griso is 12425. pete 1
GuzziMoto Posted August 28, 2019 Posted August 28, 2019 As Pete said, the speed sensor can be somewhat allergic to water. When it gets wet it can trigger that code. You can't clear the code until the issue is resolved. Drying the sensor (perhaps with a hair dryer) will make the issue go away. Sealing the sensor better will keep it from coming back.
theoneandonly Posted February 23, 2020 Posted February 23, 2020 there is a 3rd gen speedo sensor available , i haven't had one of those fail .....yet. they have been around for a few years. 1
