After a bit of help, could you recommend Guzzi part suppliers in Aussie/US/UK that might be able to supply a clutch for a 2001 V11 Sport (Rosso Mandello) my mechanic in NZ is coming up empty on after market clutch plates, and has been quoted NZ$3500 for a complete clutch assembly from Guzzi NZ. Any options for where I might be able to source a clutch without selling a kidney would be much appreciated.
Cheers
Andy
Cheers
Andy
Buy a RAM complete clutch assy from MGcycles in the states for around 600US. You can buy other clutch parts as well. Th RM uses the single plate clutch standard doesnt it?
Failing that its Stein Dinse in Germany
My understanding is that is the single plate clutch (Guzzi part no GU01084440/ Surflex clutch plate part no 83M4)  Thanks for the suggestion of MGCycles
Try Peter Kelly at Motokiwi in NZ.
Did you know about NZ Moto Guzzi rally? Also know as Tattley Rappit Rally. Its at Motueka this weekend so probably no go if your clutch need replacing.
I've got an RM to. Done 60k clutch still good.
Motokiwi had been trying to get one but apparently when it turned up wasn't the right one apparemtly. Scrambling around for an alternative.
