Bastiaan Sponton Posted October 26, 2019 Posted October 26, 2019 View days ago I had problems with shifting to third and fourth gear. I took the pre selector cover off the gearbox and found the eccentric pin on the bottom of the gearbox. How did it come off? I put it back in the hole. Its really tight, you have to use a hamer. I am sure that it doesn't come off anymore. Does anybody have experience with this? Probably it was not fitted deep enough in the hole. Today I will put it al together and see whats happening..........
Lucky Phil Posted October 26, 2019 Posted October 26, 2019 11 minutes ago, Bastiaan Sponton said: View days ago I had problems with shifting to third and fourth gear. I took the pre selector cover off the gearbox and found the eccentric pin on the bottom of the gearbox. How did it come off? I put it back in the hole. Its really tight, you have to use a hamer. I am sure that it doesn't come off anymore. Does anybody have experience with this? Probably it was not fitted deep enough in the hole. Today I will put it al together and see whats happening.......... Which eccentric pin do you mean? Some gearboxes have 1 and some have 2 but in both cases they are retained by a nut on the outside of the selector cover. Ciao
Bastiaan Sponton Posted October 26, 2019 Author Posted October 26, 2019 Verzonden vanaf mijn iPhone met Tapatalk
Lucky Phil Posted October 26, 2019 Posted October 26, 2019 23 minutes ago, Bastiaan Sponton said: Verzonden vanaf mijn iPhone met Tapatalk Ok thats a "roll" pin and is used to control over travel of the selector arm. On later transmissions its replaced by and adjustable eccentric pin. It's just a press fit in the cover. Why it came out I dont know, thats not a common event. I suggest you use some green Loctite on it if it comes out again. Have a look at my write up on the selector mechanism. Ciao 1
Bastiaan Sponton Posted October 26, 2019 Author Posted October 26, 2019 Thanks for your answer Phil. I was thinking of that loctite but its so tight fit, I just put it back. Nothing more to say about it. Now its time for RUGBY!!!!!!!
Lucky Phil Posted October 26, 2019 Posted October 26, 2019 31 minutes ago, Bastiaan Sponton said: Thanks for your answer Phil. I was thinking of that loctite but its so tight fit, I just put it back. Nothing more to say about it. Now its time for RUGBY!!!!!!! RUGBY:( not for us. Australian MotoGP Ciao 1
Bastiaan Sponton Posted October 26, 2019 Author Posted October 26, 2019 Ha New Zealand is out. Who taught about that. Went for a drive after putting everything back. Works fine again!! Philip Island, I past it on my bicycle long time ago. Back then i never realized that there was a circuit on that island . Ciao ciao
