Colorobo Posted November 10, 2019 Posted November 10, 2019 Changed to full Mistral exhaust without crossover and gave the tune up idle set at 1100. there is a bad pop at 1500. co set at 0. Had a pop or cough at 3000 to 3500 with crossover and M4 cans . any suggestions. Thanks Rob
docc Posted November 10, 2019 Posted November 10, 2019 You have no mid-point crossover and no front crossover at all?
Lucky Phil Posted November 11, 2019 Posted November 11, 2019 2 hours ago, docc said: You have no mid-point crossover and no front crossover at all? Maybe docc he means the header link pipe? CO set at zero isnt right either is it docc? Ciao 1
docc Posted November 11, 2019 Posted November 11, 2019 40 minutes ago, Lucky Phil said: Maybe docc he means the header link pipe? CO set at zero isnt right either is it docc? Ciao I mean CO at zero is better than way into the negative double digits, yah? Just trying to understand that the exhaust is "without crossover." "Full Mistral?" No matter what the set-up, my suggestion would be to perform a "Decent Tune-up" for starters . . .
Colorobo Posted November 11, 2019 Author Posted November 11, 2019 I have a crossover under the bike i meant no header crossover in front of the engine. What should my co trimm be at? Docc, Minstral headers, and cans,and crossover. sorry for being so vague. 1
docc Posted November 12, 2019 Posted November 12, 2019 All cool. Trying to figure out what the set-up is. I took the liberty of editing spelling on the original post. We're talking "Mistral", yeah? AFAIK, no one can tell whether there is a front cross-over or not. Unless it leaks, rattles, or falls off. (Yes, they can fall off! ) So, that's a pretty free-flowing exhaust. How is the intake set up? (stock air box, modified lid, gauze filter, "pods", etc.) ?
Colorobo Posted November 12, 2019 Author Posted November 12, 2019 Stock box no lid like before i changed it had M4 with some sort of xover. Ran awsome just a little pop at 3000 3500 sometimes.
docc Posted November 12, 2019 Posted November 12, 2019 So, no airbox lid at all? Just open top and what kind of filter? Have you baselined the TPS, at total closed right throttle plate, at 157 mV? Balanced the throttle bodies, how?
Colorobo Posted November 12, 2019 Author Posted November 12, 2019 K and n followed your tune up valves adjusted last year only 900 miles ago carbmate sync.
docc Posted November 12, 2019 Posted November 12, 2019 If you’re confident of the TPS position and rest of the tune, you can easily braise the value of the CO in guzzidiag. Since 1500 is just barely off idle, this *may* be enough to compensate for the freer flow. Without an exhaust gas analyzer, we’re just winging it. I have seen values of +10 to +15 make just enough difference, though. Worth trying!
Chuck Posted November 12, 2019 Posted November 12, 2019 ^^^^The Mighty Scura is *quite a bit* higher than that, so I wouldn't worry about bumping it up.
