fubar guzzi Posted November 14, 2019 Posted November 14, 2019 Just how important is the phase sensor+how do we test it?
Lucky Phil Posted November 14, 2019 Posted November 14, 2019 2 hours ago, fubar guzzi said: Just how important is the phase sensor+how do we test it? As important as it gets. You cant fully bench test it. You can check the continuity and coil resistance but sometimes they work cold and then break down with heat when the engine gets to operating temperature. Generally when they fail the engine wont start. Incorrect phonic wheel to sensor gap can cause erratic running. Ciao 2 1
Pressureangle Posted November 14, 2019 Posted November 14, 2019 27 minutes ago, Lucky Phil said: As important as it gets. You cant fully bench test it. You can check the continuity and coil resistance but sometimes they work cold and then break down with heat when the engine gets to operating temperature. Generally when they fail the engine wont start. Incorrect phonic wheel to sensor gap can cause erratic running. Ciao Yup. Mine ran well cold, but as soon as it got warm started spitting, running erratically, eventually quitting altogether. Next mornings, cold, beautiful again. I eventually ohmed the sensor on the bench with a heat gun, and it opened every time at about 230*F. 1
footgoose Posted November 15, 2019 Posted November 15, 2019 9 minutes ago, Chuck said: My bad. I blame Buffalo Trace.. Is that a new brand of Bourbon?
docc Posted November 15, 2019 Posted November 15, 2019 37 minutes ago, footgoose said: Is that a new brand of Bourbon? Ya think? Chuck's favored "flask" . . . ^^^^^^^^^ 1 1
fubar guzzi Posted December 8, 2019 Author Posted December 8, 2019 I replaced the phase sensor now it starts so--------maybe now I can make headway getting this thing road ready(only 4 months till spring)!!! Am getting to know the EV really well-----that could be good or bad !
