western trucker Posted January 22, 2020 Posted January 22, 2020 Hi there newbie here I want to take front engine bracket off for cleaning and re painting just wondering if most of the engine weight is supported by this bracket and if so what do you guys do if you wanted to remove it cheers
Scud Posted January 22, 2020 Posted January 22, 2020 You mean the front subframe? That might be a puzzle to remove without taking the engine out, but could be possible. I would get the bike vertical with the shop stand, then support the engine with a platform jack. You will need to remove the tank and bunch of other stuff.
Lucky Phil Posted January 22, 2020 Posted January 22, 2020 4 hours ago, Scud said: You mean the front subframe? That might be a puzzle to remove without taking the engine out, but could be possible. I would get the bike vertical with the shop stand, then support the engine with a platform jack. You will need to remove the tank and bunch of other stuff. You can pull the front subframe with the engine still in. Just support the front of the engine under the sump with the front wheel still on the ground. Undo the cooler mounts and let it hang by the lines and then all the rest of course including fuel tank removal. Ciao
western trucker Posted January 22, 2020 Author Posted January 22, 2020 Much as you guys said I took tank off supported engine via a strap over frame took off everything connected to subframe and managed to get it out only reason it came off was a bit of corrosion about bolts so wanted it cleaned up I will also clean up lower supports off pork chops after this support it done cheers
