LowRyter Posted April 1, 2020 Posted April 1, 2020 Mine is doing the same thing now. It will get a false neutral shifting 2-3 and 3-4. When I kick it again, it jerks and moves a gear higher than it should. If I don't use the clutch it's usually fine. I thought there was an external adjuster on it but if there is I can't figure it out. It has a the extender piece on the shifter too. Downshifting is no problem.
docc Posted April 1, 2020 Posted April 1, 2020 Simple stuff first? Fettle, tighten, shim, clean, lube, and adjust the foot lever mechanism and its connecting rod, "Heim/ Rose" joints, and lock-nut on the pivot shaft. The whole Rube Goldberg affair can get loose in eight (8!) places. Make sure the "pawl arms" stay parallel. Next, fresh fluid for the clutch. Then on to the other likely culprits. (For sure, your early sport has had the Gearbox Recall performed?)
Lucky Phil Posted April 1, 2020 Posted April 1, 2020 46 minutes ago, LowRyter said: Mine is doing the same thing now. It will get a false neutral shifting 2-3 and 3-4. When I kick it again, it jerks and moves a gear higher than it should. If I don't use the clutch it's usually fine. I thought there was an external adjuster on it but if there is I can't figure it out. It has a the extender piece on the shifter too. Downshifting is no problem. Dont even think about adjusting this on the bike,its a bench job. Docc is correct of course about the simple stuff but it may be a shifter plate off for a look see for you. Ciao 1 1
docc Posted April 1, 2020 Posted April 1, 2020 No use worrying over what's next before doing what's first. Removing and replacing the shift plate is not horrible. (A lift makes this much more pleasant!) I have had more than one V11 over that the external mechanism had just rattled itself apart and loosened up over time. Something between the vibration, exhaust heat, road spray down there, and being continually kicked (literally!) up and down.
gstallons Posted April 2, 2020 Posted April 2, 2020 3 hours ago, LowRyter said: Mine is doing the same thing now. It will get a false neutral shifting 2-3 and 3-4. When I kick it again, it jerks and moves a gear higher than it should. If I don't use the clutch it's usually fine. I thought there was an external adjuster on it but if there is I can't figure it out. It has a the extender piece on the shifter too. Downshifting is no problem. Problem solved . Use the clutch to take off & TCB !
LowRyter Posted April 2, 2020 Posted April 2, 2020 It seems to display the same symptoms as Cash's "missing pin"?
JBBenson Posted April 2, 2020 Posted April 2, 2020 I miss a shift now and again. Usually just poor form on my part. If it does it repeatedly then try the simple stuff first.
LowRyter Posted April 5, 2020 Posted April 5, 2020 OK, I took the bike out today and it shifted great, almost like butta. Only had one missed shift which is better than normal. I was out taking photos and one time the dang starter would kick, I shook it and wound right up. <duh> So whatever un-indexed in the tranny is now re-indexed (for now). It was a little bit cooler day but I still wound it up daring it to miss a shift and nothin' but good. The poor bike is due a once over, valve adjustment and a fluid change. We'll see what's up. 1
Bastiaan Sponton Posted May 30, 2020 Posted May 30, 2020 Second time the pin came out. I ordered the modification, see photo. Drilled a hol, put it in. Problem solved. It shifts better to, due the advantage of adjust. one happy biker. Verzonden vanaf mijn iPad met Tapatalk 1
footgoose Posted May 30, 2020 Posted May 30, 2020 4 hours ago, Bastiaan Sponton said: Second time the pin came out. I ordered the modification, see photo. Drilled a hol, put it in. Problem solved. It shifts better to, due the advantage of adjust. one happy biker. Verzonden vanaf mijn iPad met Tapatalk Where does that go? I am not familiar
Bastiaan Sponton Posted May 30, 2020 Posted May 30, 2020 Where does that go? I am not familiarVerzonden vanaf mijn iPad met Tapatalk 1 2
Lucky Phil Posted February 22, 2024 Posted February 22, 2024 On 1/28/2020 at 9:32 AM, LowRyter said: Guzzi Trannies have a crunchy shift from 2nd to 3rd. Being deliberate helps but not always. Really. Both of my six speeders have perfect shift action in all the gears. Phil
gstallons Posted February 23, 2024 Posted February 23, 2024 (edited) You better be glad your bike didn't hear/see this or that V11 will shift worse than a 100cc Penton. Edited February 23, 2024 by gstallons Wording
