LowRyter Posted February 15, 2020 Posted February 15, 2020 There are so many threads on the subject, I didn't know where to start. So, I'm making it worse by starting another. The Moderator is more than welcome to combine this to its proper place. Anyway, I've lost a couple of those stems and they cost $30+. I won't purchase another one but it's inconvenient when you're trying to keep track of the gas fill up. I was on a Ducati forum whining about it and got this advice: I also lost the reset knob on the Veglia speedo on my Bevel Duc and as you say they are stupid ($64!!) expensive. I discovered that the male thread on the Veglia reset shaft in the speedo was the same as the female thread on a Demel tool mandrel and the mandrels aren't expensive. I fabricated a metal eyelet and epoxied on the end of the mandrel shaft, removed the retaining screw and I keep the mandrel on my keyring. When I stop for gas I thread it onto the reset shaft, reset the trip meter and then remove it and no more lost stupid expensive knobs. 2
swooshdave Posted February 15, 2020 Posted February 15, 2020 Well, that’s dedication. The risk of stripping those fine threads would prevent me from doing that.
stewgnu Posted February 15, 2020 Posted February 15, 2020 I replaced the crappy clocks a while back, still have the old ones, you’re welcome to the stem off it if any good for you?
Chuck Posted February 15, 2020 Posted February 15, 2020 3 hours ago, stewgnu said: I replaced the crappy clocks a while back, still have the old ones, you’re welcome to the stem off it if any good for you? I would be more than happy to take those off your hands for spare parts..
stewgnu Posted February 15, 2020 Posted February 15, 2020 6 hours ago, Chuck said: I would be more than happy to take those off your hands for spare parts.. Sure thing Chuck, i’ll dig them out and email you some snaps if you like.
LowRyter Posted February 15, 2020 Author Posted February 15, 2020 I'm not having an easy time finding one. If memory serves it's a reverse thread and very small (?) metric.
Chuck Posted February 16, 2020 Posted February 16, 2020 16 hours ago, LowRyter said: I'm not having an easy time finding one. If memory serves it's a reverse thread and very small (?) metric. The rule is: if the knob is on the left hand side, it's a left hand thread.
LowRyter Posted February 16, 2020 Author Posted February 16, 2020 Yeah, I don't think there are any reverse threaded mandrels. I apologize for making a useless thread.
swooshdave Posted February 16, 2020 Posted February 16, 2020 Someone once said they were going to send me a Veglia reset knob. Didn't happen. 1
Lucky Phil Posted February 16, 2020 Posted February 16, 2020 I wonder if this might be a group project to design a full aluminium CNC replacement. Looks pretty basic to me. The knob on the end would need to be different and incorporated into the body but but apart from that. Ciao 2
Rox Lemans Posted February 16, 2020 Posted February 16, 2020 I almost busted mine off once with it being close to the headlight fairing bracketry on the Scura. I'll be ripping off my Veglia stuff once it starts to break and replacing with Speedhut. These gauges are a weak point on these bikes. Self lubricating plastic gears? C'mon! 1
PJPR01 Posted February 17, 2020 Posted February 17, 2020 I got my replacement knob from MG, but having a tough time getting it threaded on again...seems like the end onto which it has to be screwed is "drooping" a bit inside the case. Have to come up with an ingenious way of lining it up to the hole to get the new one screwed on.
Kane Posted February 20, 2020 Posted February 20, 2020 My V11 that I bought with low miles and in pretty clean condition was missing the odometer stem. These are obviously shoddy items. Why replace It with the same crappy piece? I ignore the trip meter and just count up from the odometer.
4corsa Posted February 9, 2021 Posted February 9, 2021 I got my replacement knob from MG, but having a tough time getting it threaded on again...seems like the end onto which it has to be screwed is "drooping" a bit inside the case. Have to come up with an ingenious way of lining it up to the hole to get the new one screwed on.My OEM reset knob on my '03 LeMans is in place, but has become essentially useless for resetting the trip odo. I also just received my replacement from MG, but the OEM pin does not seem to want to come out. I tried turning it clockwise (as it's reported to be reverse threaded), and just spins without backing off. I then tried counter-clockwise with the same result. It appears that whatever it is screwed into is also just turning, but without engaging the numbers dial. I guess it's time to take it apart unless someone has a simpler solution. 1
PJPR01 Posted February 9, 2021 Posted February 9, 2021 Precisely...I haven't even attempted to do it again. I just use my memory now...to track mileage.
