4 hours ago, footgoose said:
I use one of those combo gauges on my dr650. works fine
Sweet, yeah I'll have two separate gauges now but the RPM one is pretty small and discreet. I should have just ordered a trail tech Vapor gauge at this point haha. Thanks mate
Ok, got my new RPM gauge. I can set what they call the "Stroke Setting" which is how many sparks per revolution.
The V11 is 1 spark per revolution correct?
There are 8 different modes I can set this device to calculate the proper RPM as seen in the chart I placed below. The lead simply wraps around one of the ignition coil spark plug leads.
I am assuming to put the device on the 1P1R mode...but have been wrong before :)
Thanks guys, you all kick ass.
I think you will need to set it for i pulse per 2 revolutions, I assume you will be picking up the signal from just one coil.The last setting.
If you are taking pulses from the ECU its anyones guess.
BTW I think a common speedo cabe ratio is 1000 turns per mile
