fotoguzzi Posted March 19, 2020 Posted March 19, 2020 Here's what my friends Scurra FW looked like after,
Chuck Posted March 19, 2020 Posted March 19, 2020 When Pete bought the Mighty Scura and sent it to MPH to do some "maintenance" before he came to the states, one of the first things on the list was to replace the single plate clutch because of "some dangly bits" too close to the exploding flywheel.
docc Posted March 19, 2020 Posted March 19, 2020 6 hours ago, fotoguzzi said: Here's what my friends Scurra FW looked like after, These are great images, yet I was always confused by my misunderstandings until I got it all apart and realized my history with cars had me confused. If I am correct the image above is the front of the actual flywheel that mates to the crankshaft. The toothed ring/"chain ring" that is turned by starter is mounted behind this and is not the actual flywheel as in the cars I have been accustomed to. Perhaps fueling my confusion, the flywheel is not numbered in the parts diagram for the clutch and is not actually considered part of the "clutch" assembly : The flywheel #19 (and "chain ring" #22) is, instead, shown with the crankshaft and piston/cylinder assembly: It probably has not helped that we have so often stated concerns about failure of the "single plate clutch" when, in fact, the clutch does not fail but the aluminum flywheel that was used with it on the Rosso Mandello, Scura, and Tenni that is the singular fail point. [Just a wee stab at some clarification for those that may be wading through our discourse. ] 1
stewgnu Posted March 19, 2020 Posted March 19, 2020 2 hours ago, fotoguzzi said: Here's what my friends Scurra FW looked like after, Wow, that’s fairly alarming
Chuck Posted March 19, 2020 Posted March 19, 2020 You think that's alarming.. think about it coming loose at 6000 rpm. I wouldn't want my dangly bits around, either.. 2
docc Posted March 19, 2020 Posted March 19, 2020 2 hours ago, fotoguzzi said: Here's the other side Good image of the rear aspect of the clutch assembly and "toothed gear." The flywheel is not visible from this side (correct?) as the clutch resides inside of it and the toothed gear/"chain ring" bolts to it.
fotoguzzi Posted March 19, 2020 Posted March 19, 2020 Correct, the FW is below but you can't see it.. I still have the parts if you need to see something else. 1
docc Posted March 19, 2020 Posted March 19, 2020 Thank you, Sir! Just trying to contribute the outstanding documentation so others can put this to good use. Here is an image of the steel flywheel with the toothed gear/"chain ring" removed: And one showing the steel flywheel in the upper right: 1
bbolesaz Posted March 23, 2020 Posted March 23, 2020 I'm confused about something - Is the starter ring on the tranny side of the clutch? If so, does that mean that if I pull the clutch, the starter won't turn the engine? Haven't tried it.
Tomchri Posted March 23, 2020 Posted March 23, 2020 29 minutes ago, bbolesaz said: I'm confused about something - Is the starter ring on the tranny side of the clutch? If so, does that mean that if I pull the clutch, the starter won't turn the engine? Haven't tried it. NO Cheers tom.
Lucky Phil Posted March 23, 2020 Posted March 23, 2020 40 minutes ago, bbolesaz said: I'm confused about something - Is the starter ring on the tranny side of the clutch? If so, does that mean that if I pull the clutch, the starter won't turn the engine? Haven't tried it. This sounds like a brain fart question:) My bike wont engage the starter unless the clutch is pulled in to start with. Does that answer the question? Ciao 1
