Hello,
Whilst continually nitpicking over my V11 in lockdown, I noticed I am missing a subframe to engine bolt, this wouldn't usually be a problem as I would just find out what it is and buy one;  but as this is a 2003 sport it seems to have these mysterious aditional legs on the subframe (part 7 in the diagram) which no parts diagrams seem to have a reference to the bolt that actually holds this on.
Looking on the other side, it is a large mushroom allen head bolt, but I don't want to remove the remaining one to check the size, anyone have any information?
Thanks
  On 4/9/2020 at 12:10 PM, gstallons said:
I don't understand what you want . Is it part # 9 ?
Expand
No, sorry for not being clear; it is the bolt that goes through the front arms of part 7, they are not listed as a part in any diagrams.
(circled in photo)
It is a  low profile socket head capscrew .   It is a 12X35 1.75 thread pitch . there is a Schnorr washer along w/ Loctite .
Expand
Thank you so much. Is this knowledge through measuring it or am I missing a reference somewhere?
I unscrewed the capscrew from my bike and measured it .
  • Like 7
Expand
So 1 12mm x 35 x 1.75 button head cap screw grade 8, blue loctite and a washer. Cant really imagine why it would be 12mm screw, a 10 would have been more than adequate in my mind but that's Guzzi. Weight, what is this thing weight :)
I wouldnt worry about the snoring washer if you cant source one, a plain one with the loctite will be fine.
They are Schnorr washers . The company is an Ann Arbor , Mi. They invented these .
 They are under most of the fasteners on this bike .
Whatever fits the bolt an looks good can work . If the Schnorr washer isn't readily available , I would use a grade 8 flat washer .
How that bolt got out .............IDK . It took a long time to remove .
  • Haha 1
Expand
Various bits have been painted (with wildly varying paint and skill), so I guess it wasn't put back in, or it wasn't put back in tight after painting the engine or subframe.
Expand
well idk neither... i looked down last week and saw one of my clipon bolts was missing... make you wonder about all those bolts you’ve messed with
Hey , about 10 yrs ago I wen to an open house at the BMW store in Cape G , Mo. After I got home I found one of the slip-ons hanging DOWN and about to fall off . ---- ! The best of us miss things all the time . If you ride with a pack , everyone look at each other's bike . IDK why , but you will see someone else's "fault" before you see your own .
 It doesn't hurt to do a pre-flight , because there aren't many unnecessary parts on a bike or aircraft .
