Colorobo Posted April 20, 2020 Posted April 20, 2020 If the tps voltage is higher is there more fuel or less. I am still running lean closed air screws and that helped. had them open 1/2 a turn and had a pop cough of idle. Thanks RP
docc Posted April 20, 2020 Posted April 20, 2020 So . . . good question and worth working through. Moved this topic to Technical Topics . . . Stand by. Pretty sure good answers will flow from your good question.
docc Posted April 20, 2020 Posted April 20, 2020 Short answer is: no, you cannot add or subtract fuel simply by rotating the TPS. While this was once thought, it turns out the TPS baseline is entirely about indexing the ECU "map" to the throttle body openings. Best to index it accurately. Take a look at the "Decent Tune-up" procedure. It is a great starting point.
Lucky Phil Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 12:14 AM, docc said: So . . . good question and worth working through. Moved this topic to Technical Topics . . . Stand by. Pretty sure good answers will flow from your good question. Expand Higher the voltage the more fuel. Ciao
Lucky Phil Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 12:18 AM, docc said: Short answer is: no, you cannot add or subtract fuel simply by rotating the TPS. While this was once thought, it turns out the TPS baseline is entirely about indexing the ECU "map" to the throttle body openings. Best to index it accurately. Take a look at the "Decent Tune-up" procedure. It is a great starting point. Expand Ok docc, I will be happy to stand corrected here but if you move the TPS to a higher voltage output for the same throttle plate position wont that be telling the ecu that the throttle is open a greater amount than it actually is and "by and large" give longer injector duration for a given rpm because it thinks the throttle is actually open more than it is? Thats always been my understanding, I might be wrong. You set the base TPS voltage with the throttle plates closed to give the ecu the shut limit and then it calculates throttle plate position from there. If say you have the plates closed but set the TPS voltage at 3 deg open the ecu will supply fuel or injector pulse width advanced 3 degrees across the board which would generally mean more fuel. I may have missed something here, others may know the details better. Ciao
docc Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 12:29 AM, Lucky Phil said: Ok docc, I will be happy to stand corrected here but if you move the TPS to a higher voltage output for the same throttle plate position wont that be telling the ecu that the throttle is open a greater amount than it actually is and "by and large" give longer injector duration for a given rpm because it thinks the throttle is actually open more than it is? Thats always been my understanding, I might be wrong. You set the base TPS voltage with the throttle plates closed to give the ecu the shut limit and then it calculates throttle plate position from there. If say you have the plates closed but set the TPS voltage at 3 deg open the ecu will supply fuel or injector pulse width advanced 3 degrees across the board which would generally mean more fuel. I may have missed something here, others may know the details better. Ciao Expand I always thought that, too. And even tried to "add fuel" that way on the idea that the motor must be "lean." Just turns out more complex than that because of the "mapping." @Meinolf understands this better than anyone I know.
Lucky Phil Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 12:34 AM, docc said: I always thought that, too. And even tried to "add fuel" that way on the idea that the motor must be "lean." Just turns out more complex than that because of the "mapping." @Meinolf understands this better than anyone I know. Expand Hopefully he'll chime in. Thinking about it docc the "overall richening" issue not being valid will be because at some points in the map and engine operating envelope the fuel pulse width and therefor delivery will actually be reduced at least not increased due to volumetric efficiency considerations at different rpm and load points. Ciao
docc Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 12:42 AM, Lucky Phil said: Hopefully he'll chime in. Thinking about it docc the "overall richening" issue not being valid will be because at some points in the map and engine operating envelope the fuel pulse width and therefor delivery will actually be reduced at least not increased due to volumetric efficiency considerations at different rpm and load points. Ciao Expand Yessir. That is what I gathered from it being more than just linear. Like when I just put bigger jets in my Holley spreadbore . . .
MartyNZ Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 12:06 AM, Colorobo said: If the tps voltage is higher is there more fuel or less. I am still running lean closed air screws and that helped. had them open 1/2 a turn and had a pop cough of idle. Thanks RP Expand TPS voltage affects more than just injection duration. Injection and ignition timing are also affected. See https://www.v11lemans.com/forums/index.php?/topic/17865-v11-ecu-diagnostics-and-reprogramming/&do=findComment&comment=207884 The engine is transformed from smooth & sweet to brutally rough if you set the TPS wrong. Try it, but be ready on the kill switch. 1 1
Lucky Phil Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 12:56 AM, docc said: Yessir. That is what I gathered from it being more than just linear. Like when I just put bigger jets in my Holley spreadbore . . . Expand My friend at one point was modifying Harley pressure regs to be adjustable ( same ones as our bike runs) so you could easily richen the whole map. He accepted it was a band aid because he knows a lot about efi stuff but it was "good enough" for the Harley guys and actually solved the running issues they had at the time. I spent some time assembling them and setting them on the test rig. Ciao
Lucky Phil Posted April 20, 2020 Posted April 20, 2020 On 4/20/2020 at 1:17 AM, MartyNZ said: TPS voltage affects more than just injection duration. Injection and ignition timing are also affected. See https://www.v11lemans.com/forums/index.php?/topic/17865-v11-ecu-diagnostics-and-reprogramming/&do=findComment&comment=207884 The engine is transformed from smooth & sweet to brutally rough if you set the TPS wrong. Try it, but be ready on the kill switch. Expand Yes of course, a good refresher. Thanks Ciao
docc Posted April 20, 2020 Posted April 20, 2020 Best I can gather from all the respectable contributors is that if you really want that much more out of a V11, take off the license plate and back it up to a Roller 8 Valve. Just be willing to give up your quickie RedFrame, if ya gots one. Otherwise, the V11 can really be tuned very finely, of you are wiling to take the time and trouble. 1
