80CX100 Posted June 6, 2020 Posted June 6, 2020 Hammershaug, I feel for you, that's a lot of pain to process. While you're digesting all that life has thrown at you, please be mindful and careful. Hope your bike comes out the basement easily, and you get some quality time with it. Kelly 1
docc Posted June 6, 2020 Posted June 6, 2020 Thanks for letting us know. This makes me look even more forward to "Greenie Coming Up . . ." as I know your friends will be there with you. Hang in there, friend. 1
Tomchri Posted June 6, 2020 Posted June 6, 2020 Sorry to hear that Jan, my condolences. Cheers tom. 1
hammershaug Posted June 7, 2020 Author Posted June 7, 2020 Thanks for the compassion, friends. I appreciate your kind words. Yes, I'm very eager to take «miss greenie» for a trip, so I have to get her up soon. Here's my project status list: Oil Pan is glass bead blasted, painted and back in place. New gasket, oil filter, and bolts. The battery holder had some rusty spots. Sanded, painted and ready to be mounted. Burned 30A fuse/fuse-holder replaced with Tyco 30A breaker. The unoriginal and stiff intake rubbers are replaced. Fuel filter and fuel hoses are replaced. Throttle bodies are cleaned and mounted. Partly cleaned in my ultrasonic cleaner with kerosene and manually with brake cleaner. The defective electric petcock is replaced with a manual type. External ground (1,5mm2) to voltage regulator is replaced with new (10mm2/7 AWG) https://www.flickr.com/photos/hammershaug/albums/72157714007221726/page2 Haven't decided about replacing the pawl spring now, or after season. Haven't decided to put back the air filter box or the new, big K&N's. Yes, I know, the warning... but I like it that way;) 1
Lucky Phil Posted June 7, 2020 Posted June 7, 2020 On 6/6/2020 at 7:04 PM, hammershaug said: Hello guys! There has been another delay in my project due to the passing of my father. We lost him May 17th, our national day. He had suffered from Alzheimer's disease since 2013, and I sat with him when he died. Because of that all my time has gone with the funeral and supporting my mum. I have lost my wife, my father in law, my uncle and my father in 2,5 years. Sick and tired of death. Anyway, the Greenie is in good health! I hope to lift her out of the basement soon. Yes, @docc it's about time, and I will of course post a mirror image Thats a lot of grief to process. Keep going, better times ahead. Ciao 1
hammershaug Posted June 7, 2020 Author Posted June 7, 2020 Too many connectors and bad memory? I'm not sure where those connectors should be... Can't find yellow/white+black wiring in Carl Allison's wiring diagram. From Carl's diagram the fuel level switch is wired with grey/white. The electric petcock(or fuel solenoid valve) should be yellow/blue. None of them was functional on my V11.
LowRyter Posted June 7, 2020 Posted June 7, 2020 don't plug the petcock plug into the fuel level sensor. It'll burn the sensor up.
Tomchri Posted June 7, 2020 Posted June 7, 2020 Right side connector,,, I'm quite sure is the sensor in the air box, I will double check tomorrow. I like it CLEAN to, nice. Cheers tom.
Lucky Phil Posted June 7, 2020 Posted June 7, 2020 The fuel tap appears to be black/yellow and black. The tap is wired to the F8 fuse so if you have a meter you can trace it back to there. Ciao
andy york Posted June 7, 2020 Posted June 7, 2020 Right side connector is the temp sensor located in the stock air box left side connector is fuel level gauge at least on my bike they are Andy 2
swooshdave Posted June 8, 2020 Posted June 8, 2020 Did someone say they didn't like bar end mirrors? They give the absolute best view behind you but they do add to the width. 3
Lucky Phil Posted June 8, 2020 Posted June 8, 2020 5 hours ago, hammershaug said: Too many connectors and bad memory? I'm not sure where those connectors should be... Can't find yellow/white+black wiring in Carl Allison's wiring diagram. From Carl's diagram the fuel level switch is wired with grey/white. The electric petcock(or fuel solenoid valve) should be yellow/blue. None of them was functional on my V11. I can say for sure the r/h sensor in the first image is for the airbox ambient temp sensor. Ciao 1
footgoose Posted June 8, 2020 Posted June 8, 2020 1 hour ago, swooshdave said: Did someone say they didn't like bar end mirrors? They give the absolute best view behind you but they do add to the width. Great job on the Norty Dave 1
hammershaug Posted June 8, 2020 Author Posted June 8, 2020 Right side connector,,, I'm quite sure is the sensor in the air box, I will double check tomorrow. I like it CLEAN to, nice. Cheers tom.Yes of course! It has to be air box sensor. Forgot about that. I clean every connector with electro cleaner. The fuel level connector hasn’t been used for a while obviously, so it’s very dirty.Sent from my iPhone using Tapatalk
Lucky Phil Posted June 8, 2020 Posted June 8, 2020 2 hours ago, swooshdave said: Did someone say they didn't like bar end mirrors? They give the absolute best view behind you but they do add to the width. Yes it's a problem that kind of fairing with regards to mirrors. I think I prefer fairing mounted ones but they need to be the "right ones" Ciao
