pete roper Posted June 16, 2021 Share Posted June 16, 2021 You know how many complaints or even suggestions of dissatisfaction I've heard about Joe's gears? None! Not one! Nada! If you want gears they are the ONLY decent option. The End. Oh, and John, i Havant been ignoring you. I've just been busy with a lot of non motorbike crap. I'll PM you when I have a moment. Sorry. Pete 1 Link to comment Share on other sites More sharing options...
Weegie Posted June 16, 2021 Share Posted June 16, 2021 That's Ok Pete, when you get the time, thanks for letting me know I've just been pestering the Bayjasus outta @Lucky Phil instead Link to comment Share on other sites More sharing options...
Pressureangle Posted June 27, 2021 Share Posted June 27, 2021 Rather than start a new thread, I'll just append to this one. I've installed my Caruso gears, I'll add a sound file if I can figure out how to do that after it's on the ground. I was surprised at how much sludge was in the bottom of the front chaincase. I'm now installing my own Roper Plate, we'll see what the bottom of the pan looks like. Also, I discovered that my cam sensor clearance is...frighteningly close. .002" or so, but with zero witness marks on the sensor after 15k miles I'll not touch it. Whoopsy- imagine my surprise when I actually got the centerpunch and drill straight enough to save the original threads. 4 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted June 28, 2021 Share Posted June 28, 2021 5 hours ago, Pressureangle said: Rather than start a new thread, I'll just append to this one. I've installed my Caruso gears, I'll add a sound file if I can figure out how to do that after it's on the ground. I was surprised at how much sludge was in the bottom of the front chaincase. I'm now installing my own Roper Plate, we'll see what the bottom of the pan looks like. Also, I discovered that my cam sensor clearance is...frighteningly close. .002" or so, but with zero witness marks on the sensor after 15k miles I'll not touch it. Whoopsy- imagine my surprise when I actually got the centerpunch and drill straight enough to save the original threads. I wouldn't leave it with 0.002" clearance myself. Or is that 0.020". Ciao 1 Link to comment Share on other sites More sharing options...
Chuck Posted June 28, 2021 Share Posted June 28, 2021 Min spec is .023" from memory. 1 Link to comment Share on other sites More sharing options...
ScuRoo Posted June 28, 2021 Share Posted June 28, 2021 15 hours ago, Pressureangle said: I've installed my Caruso gears, I'll add a sound file if I can figure out how to do that after it's on the ground. YES PLEASE!👏 ...would absolutely love to hear the aural side effect one gets for their money. If it was somewhat akin to aural sex going hard thru the gears it might be a worthy accompaniment to a good set of pipes! Link to comment Share on other sites More sharing options...
Pressureangle Posted June 28, 2021 Share Posted June 28, 2021 10 hours ago, Lucky Phil said: I wouldn't leave it with 0.002" clearance myself. Or is that 0.020". Ciao 2 things here- First, it's been that way for ~15k miles and there's no evidence of contact. Second, my measurement is imperfect. I used a feeler gauge, and the tip of the sensor is not perfectly flat so the 'sensor' part is slightly retracted from the edges. Also, I didn't have the gear on so there's some possibility that the trigger was not in perfect alignment as it is tightened. I *think* I checked it when I replaced the sensor when I first got the bike by the normal 'remove the spacer and test' method, but I don't recall distinctly. I'm quite familiar with trigger and wheel inductive sensors; the spec for all of them is usually .025" plus or minus .005". The signal strength decreases by the square of the distance, so closer is better; the clearance is not for signal but rather for imprecision in tolerance such as out of round or crank flex, or in the case of wheel speed sensors, debris collection. So yes there would be a concern if it was a new install, but proof's in the pudding and I'd worry more about causing some running change than suddenly contacting the trigger. But now you've made me overthink it. Who sells shims? Link to comment Share on other sites More sharing options...
Lucky Phil Posted June 28, 2021 Share Posted June 28, 2021 15 minutes ago, Pressureangle said: 2 things here- First, it's been that way for ~15k miles and there's no evidence of contact. Second, my measurement is imperfect. I used a feeler gauge, and the tip of the sensor is not perfectly flat so the 'sensor' part is slightly retracted from the edges. Also, I didn't have the gear on so there's some possibility that the trigger was not in perfect alignment as it is tightened. I *think* I checked it when I replaced the sensor when I first got the bike by the normal 'remove the spacer and test' method, but I don't recall distinctly. I'm quite familiar with trigger and wheel inductive sensors; the spec for all of them is usually .025" plus or minus .005". The signal strength decreases by the square of the distance, so closer is better; the clearance is not for signal but rather for imprecision in tolerance such as out of round or crank flex, or in the case of wheel speed sensors, debris collection. So yes there would be a concern if it was a new install, but proof's in the pudding and I'd worry more about causing some running change than suddenly contacting the trigger. But now you've made me overthink it. Who sells shims? HMB Guzzi, Stein Dinse. Ciao Link to comment Share on other sites More sharing options...
Pressureangle Posted June 28, 2021 Share Posted June 28, 2021 6 minutes ago, Lucky Phil said: HMB Guzzi, Stein Dinse. Ciao Thanks. Now this is turning into a sensor thread. The failed sensor I bought the bike with was swelled badly enough that it was hard to remove. I wonder if that's something that could push the sensor tip nearer the trigger, without actually failing the sensor. Link to comment Share on other sites More sharing options...
Chuck Posted June 28, 2021 Share Posted June 28, 2021 FWIW, back when I used to work on Centauros for guys that couldn't find a dealer to do it, I found one sensor that had actually been milled by the flywheel. Still worked. Link to comment Share on other sites More sharing options...
gstallons Posted June 28, 2021 Share Posted June 28, 2021 It happens and all reasoning says NO it should not work . I don't see how ? Link to comment Share on other sites More sharing options...
Chuck Posted June 28, 2021 Share Posted June 28, 2021 I deposited that one in the "Some things are not meant to be understood" file. 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted June 28, 2021 Share Posted June 28, 2021 2 hours ago, Chuck said: FWIW, back when I used to work on Centauros for guys that couldn't find a dealer to do it, I found one sensor that had actually been milled by the flywheel. Still worked. My Centauro engine had been contacting the sensor as well when I bought it. Don't know if it was affecting running but it deposits metal in the oil. Ciao 1 Link to comment Share on other sites More sharing options...
Pressureangle Posted June 29, 2021 Share Posted June 29, 2021 17 hours ago, gstallons said: It happens and all reasoning says NO it should not work . I don't see how ? The tip is not critical to function, to a point. https://physics.stackexchange.com/questions/369212/inductive-sensor-how-does-it-work 1 Link to comment Share on other sites More sharing options...
Pressureangle Posted June 30, 2021 Share Posted June 30, 2021 Ok, up and running. I of course adjusted the valves, the exhausts were very tight cold, which explains why it had been a little snotty to start and warm up. My bad, it's probably been 7k miles since last adjustment. Valves aside, the thing started better than ever, it seems, and even 1/2 warm it idles at 1250rpm or so, up from ~1k-ish. Somebody elsewhere said that was their experience too, so there be a rebalancing coming soon. The gears are not as loud as some were hoping, they're pretty hard to discern above the valve clatter. Overall it hits me as far more happy and stable than with the chain (and tight valves). Here's your movie short.Joe's Gears 2 1 Link to comment Share on other sites More sharing options...
