4corsa Posted May 26, 2020 Posted May 26, 2020 My newly acquired '03 Le Mans arrived without a fuse box cover. Looking to buy a used one. Thanks!
4corsa Posted May 27, 2020 Author Posted May 27, 2020 Guzzi no longer supplies the V11 Fuse Block. Luckily I found the OEM ATC & ATO block offered for $11 at Del City.I've also added this under the Forum's Encyclopedia of Compatible parts. 1
docc Posted May 27, 2020 Posted May 27, 2020 Hey, good find! I see you added it to The Encyclopedia of Compatible Parts. The clear/slotted lid is novel, yet would be much more effective if ATC fuses were still translucent and not opaque. WTH is up with that change? Of course, you could still make a label for the lid showing fuse functions. I added a more complete "side stand oriented" function sheet to the inside of the tailpiece for roadside troubleshooting . . . 1 1
4corsa Posted May 27, 2020 Author Posted May 27, 2020 Awesome - thanks Docc. I will be unapologetically plagiarizing your labels! 1
docc Posted May 27, 2020 Posted May 27, 2020 35 minutes ago, 4corsa said: Awesome - thanks Docc. I will be unapologetically plagiarizing your labels! Just be aware of my modified wiring . . . 1
