po18guy Posted May 31, 2020 Posted May 31, 2020 NOS. If so, $19.95 USD starting bid plus shipping from Massachusetts. https://www.ebay.com/itm/Moto-Guzzi-flywheel-new/114238191085?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
pete roper Posted May 31, 2020 Posted May 31, 2020 Methinks it's probably the ring gear assembly from one of the single platers used on the Scura/Rosso Mandello etc. it's too big for a smallblock and it's not an 8V as they have a separate ring gear. 1
Lucky Phil Posted May 31, 2020 Posted May 31, 2020 51 minutes ago, pete roper said: Methinks it's probably the ring gear assembly from one of the single platers used on the Scura/Rosso Mandello etc. it's too big for a smallblock and it's not an 8V as they have a separate ring gear. Yes I thinks so as well. Ciao
Baldini Posted June 4, 2020 Posted June 4, 2020 As Pete says, that looks like a (two part) Scura ring gear assembly. Only difference that I can see is, on mine the gbox-facing side of the ring gear itself is relieved around it's circumference. I'm guessing it may be the RAM version, but I can't check cos it's in the trans.
