docc Posted November 7, 2022 Posted November 7, 2022 Seems your V11 runs right. GuzziDiag connectivity is a mystery to me. 1
80CX100 Posted November 7, 2022 Posted November 7, 2022 2 minutes ago, docc said: Seems your V11 runs right. GuzziDiag connectivity is a mystery to me. Excellent, tks. From my understanding of the schematic and the info from Roy,,, the little jumper wire I had off and then reconnected was from ECU relay 4 pin 87,,, to Coil/injector? Relay 5 pin 85?. If I reconnected those back incorrectly on the wrong pins,,, would it be possible, that the side stand/neutral switches are still acting normal,,, but somehow Guzzidiag won't connect if the side stand is up,, due to the funky circuits, you had mentioned earlier through the run switch?
80CX100 Posted November 7, 2022 Posted November 7, 2022 4 hours ago, docc said: Seems your V11 runs right. GuzziDiag connectivity is a mystery to me. Hey Docc, After studying Stewgnu's schematic, I realize that my relays and the wiring connections appear to all be in order. The guzzidiag connection issue might be one of those unsolved mysteries, lol 1
