gstallons Posted August 30, 2020 Posted August 30, 2020 For Docc & Phil : they have been "in tank" since the 80s and the tanks have been both metal and plastic . 1
bbolesaz Posted August 31, 2020 Posted August 31, 2020 None of the in tank electronics "spark". If they do, that's badness. And yes, the pump motor is brushless. Edit - I don't think the pump is brushless in early 2000's. The brushless motors are becoming more common. I know this because my company build the controller chips used for these motors. (A good business for us!). It's the concentration of the fuel vapor that prevents explosions. From Google - "The reason electric, tank- mounted fuel pumps do not cause explosions is that the concentration of fuel vapors is too high to allow an explosive mixture. The volatile (which in this context refers to a tendency to evaporate) nature of gasoline causes fuel vapors to take up any empty space as the fuel tank is emptied. Even if you completely empty a tank, open its access ports, and allow it to sit open, the concentration of vapors INSIDE the tank will still be too high to explode. Now, OUTSIDE the tank is a different story, and for this reason, one must use caution when performing any sort of repair or maintenance to a fuel tank, regardless of the type of pump used on the vehicle." 2
