jwatches Posted September 7, 2020 Posted September 7, 2020 Where can I get a stock 2004 throttle tube, or a complete throttle assembly that is compatible with the V11 Sport throttle cables (fuel injected).
fotoguzzi Posted September 7, 2020 Posted September 7, 2020 I have a used one from a Centauro, if you can determine it's the same (probably is) I'll send to you for the cost of shipping.
jwatches Posted September 7, 2020 Author Posted September 7, 2020 Thanks. I will try to confirm the parts are the same. The Centauro appears to have been made 96-98, but maybe the same. 1
fotoguzzi Posted September 7, 2020 Posted September 7, 2020 I'll get a pic, stand by I'll be back in an hour with it.
docc Posted September 7, 2020 Posted September 7, 2020 @jwatches . . . Seems like the later V11 had a different throttle cable than the early RedFrames. GU 01117590 ?
jwatches Posted September 7, 2020 Author Posted September 7, 2020 The key dimension is the width of the cable ramp. It is thinner than what I have found for other throttle tubes (5.80mm).
jwatches Posted September 7, 2020 Author Posted September 7, 2020 6 minutes ago, docc said: @jwatches . . . Seems like the later V11 had a different throttle cable than the early RedFrames. GU 01117590 ? The throttle tube has a part number 3081, but no indication of manufacturer.
jwatches Posted September 7, 2020 Author Posted September 7, 2020 Thanks for the photo @fotoguzzi. Unfortunately that is a single cable system. My V11 LeMans has a push-pull, dual cable throttle.
fotoguzzi Posted September 7, 2020 Posted September 7, 2020 Ok good luck, you might try one from an EV 1100, I think they used the same thing on them after 2000 or so.. ask over at wildguzzi.com
docc Posted September 7, 2020 Posted September 7, 2020 35 minutes ago, jwatches said: The throttle tube has a part number 3081, but no indication of manufacturer. Okay, sorry, I was thinking of the cable. I have one for a late model V11 if anyone needs it.
