Lucky Phil Posted September 29, 2020 Posted September 29, 2020 For those interested in 78 mm crank differences. On the left a Centauro and later Daytona crank. On the right a 78 mm Cali crank. I think the earlier Daytona cranks that used the standard rods also used the Cali version with the balance adjusted but as can be seen the difference between the Cali 78 mm crank and the Centi/Later Daytona cranks is a lot more than just a dynamic balance adjustment. The 78 mm Cali crank is just a heavier version at 8.3 kg compared to 7.5 kg for the Centi and later Daytona Cranks. No wonder the lighter Centi crank and single plate flywheel feels like a Ducati engine. Ciao 3
pete roper Posted September 29, 2020 Posted September 29, 2020 Would you like me to weigh a 1200 crank for comparison?
Lucky Phil Posted September 29, 2020 Author Posted September 29, 2020 1 hour ago, pete roper said: Would you like me to weigh a 1200 crank for comparison? That would be good Pete, and an image? Ciao
docc Posted September 29, 2020 Posted September 29, 2020 Any hopes of comparing these with a V11 Sort/LeMans cranks? And, yes, clothed please!
Admin Jaap Posted September 29, 2020 Posted September 29, 2020 2 hours ago, pete roper said: With or without my clothes on? There are different forums for those kind of pictures, but I'm sure you know that already. 1 2
Cabernet Posted September 29, 2020 Posted September 29, 2020 Just weighed my 2002ish V11's old crank. 7.3kg 1
pete roper Posted September 30, 2020 Posted September 30, 2020 8V 1200 crank. 7.1 kg. Probably because it doesn't have the enormous steel penis sticking out the front for the alternator to hang off. [img]https://live.staticflickr.com/65535/50399815216_0657dc618d_z.jpg[/img][/url] Also note the absence of a sludge trap in the crankpin. [img]https://live.staticflickr.com/65535/50399121498_501d941d47_z.jpg[/img] Big end lubrication is taken care of by two cross-drilling's from the main bearings to the crankpin. I assume that the sludge trap was deleted for cost/saving purposes. They made a lot of bleating noises about how much stiffer the *New* crank was but Guzzi big block cranks have never been whippy like shitty BMW cranks so I think that was just waffle to justify their cheapskatery. [img]https://live.staticflickr.com/65535/50399121443_74161b6abf_z.jpg[/img] Someone else will have to open the links up, m not clever enough. 2
Lucky Phil Posted September 30, 2020 Author Posted September 30, 2020 1 hour ago, pete roper said: Thanks Docc Nice Pete, not too impressed with the sludge trap omission. There's always quite a bit of rubbish in there and its nice to know you've got it cleaned out properly if you have the engine apart. Spose there's quite a few around with DLC coating living in the pin. Ciao
pete roper Posted September 30, 2020 Posted September 30, 2020 I doubt there is much of anything in the oil galleries. The cross-drilling's go from the top of the webs where the trap used to be, all the way through the pin both ways to the front and rear journals. There are then cross drilling's in the pin, (One per rod bearing only. Another weak point in my book.) that intersect with the through drilling's. The through drilling's are sealed with grub screws. ive had a couple of high mileage motors apart and removed those grub screws and had a poke down the galleries with a probe and flushed them out well and there was no detritus in them, not even in the 'Blanked off' part of the gallery so I assume that the engine is dependent on the filter for catching the mank. It also probably explains why a couple of motors have died after we rollerised them. Both of those had done over 60,000km prior to rollerisation and both had significant DLC contamination of the big end shells.
Lucky Phil Posted September 30, 2020 Author Posted September 30, 2020 2 hours ago, pete roper said: I doubt there is much of anything in the oil galleries. The cross-drilling's go from the top of the webs where the trap used to be, all the way through the pin both ways to the front and rear journals. There are then cross drilling's in the pin, (One per rod bearing only. Another weak point in my book.) that intersect with the through drilling's. The through drilling's are sealed with grub screws. ive had a couple of high mileage motors apart and removed those grub screws and had a poke down the galleries with a probe and flushed them out well and there was no detritus in them, not even in the 'Blanked off' part of the gallery so I assume that the engine is dependent on the filter for catching the mank. It also probably explains why a couple of motors have died after we rollerised them. Both of those had done over 60,000km prior to rollerisation and both had significant DLC contamination of the big end shells. Ok Pete so its now a solid pin apart from some maybe 5-6 mm drillings from the mains and the same size through the pin intersecting them. A largely solid pin then? 7.1 KG seems pretty light as well. Ciao
po18guy Posted September 30, 2020 Posted September 30, 2020 On 9/29/2020 at 1:19 AM, Lucky Phil said: Ciao Smokes! I thought the Yammie YDS3/YM1 had a lot of crank protrusion! This on the clutch side. Generator on the stub side.
