Brian north Posted November 13, 2020 Posted November 13, 2020 Hey I'm a newbie here and to the Moto guzzie world. Bike cuts at 3-5000 rpm for a split second. The tach drops to zero but instantly fires back up. Other problem is there are no mechanics who work on guzzie in my area. I appreciate any and all help
Tomchri Posted November 13, 2020 Posted November 13, 2020 Have you checked the charging, special the 2 bullet connectors from the stator ? what kind of relays ? EVERY electrical connection on the bike needs to be checked and treated with Caig Deoxit or similar. What does your 30amp fuse look like, the green one ? Could be quite a few things, but don't worry , you are definitely on the right place to get sorted. Welcome to the forum, and shortly someone a lot more electrical than me will come along. Cheers tom 2
GuzziMoto Posted November 13, 2020 Posted November 13, 2020 That sounds like an electrical issue. Check connections, as mentioned. Also, check your ignition switch.
Rolf Halvorsen Posted November 13, 2020 Posted November 13, 2020 I suspect that the ignition sensor in front left og the engine is bad. Have seen similar behavior before. Article number is 01721600. The distance between the sensor head and the entrance should be aroung 0,5 - 0,7mm. Thin alunimum sheets help to get this correct. You also need a new O-ring to seal it against moist. Chime in if you need more details.
Brian north Posted November 13, 2020 Author Posted November 13, 2020 4 hours ago, Rolf Halvorsen said: I suspect that the ignition sensor in front left og the engine is bad. Have seen similar behavior before. Article number is 01721600. The distance between the sensor head and the entrance should be aroung 0,5 - 0,7mm. Thin alunimum sheets help to get this correct. You also need a new O-ring to seal it against moist. Chime in if you need more details. How can I check the sensor?
Brian north Posted November 13, 2020 Author Posted November 13, 2020 Well I'm pretty sure the bike is good. Checked ignition switch and everything was good. Unplugged powercommander and swapped 5 relay for 3 relay. Hit the road for one hell of a great ride. I love this bike. Thank you for all the help. I'm sure I'll be asking more questions 2
Lucky Phil Posted November 13, 2020 Posted November 13, 2020 The most important question with any form of running issue.......Is it fitted with a Power Commander? Ciao 1
docc Posted November 13, 2020 Posted November 13, 2020 Heh, yeah, I took my relay post down because I thought it might just confuse the issue(s). Could have been just the PC, Brian north. Otherwise, the V11 is probably better thought of as a journey, or a process, rather than a series of problems and repairs. Tell us more about the "01 v11 s" . . . how long have you had it, miles on it, other modifications . . . You know, the important stuff, like, is it silver?
fotoguzzi Posted November 14, 2020 Posted November 14, 2020 As too relays, the factory stock Siemens relay were notoriously bad. If still in there replace them all. A good source in the states is dpguzzi.com. (Pyro Dan)
Chuck Posted November 15, 2020 Posted November 15, 2020 I *like* Pyro Dan, and his relays are very good. That said, for the V11S, Omrons are more better. 1 1
