Need to start on some winter stuff on the 97 sport. Is there a good way to dump the line pack on the fuel lines? Thanks
On an injected 1100 Sport-i, like the V11, you can disconnect the return fuel line to the tank and it will drain the lines (and probably the filter).
If you have a fuel tank petcock closed, removing the output fuel line from there will help purge the lines/filter/pump through to the return line at the regulator. Be prepared to catch 100-200 ml of fuel. It's always a nasty job.  NO :rasta: !!!
[This is from my early V11/external fuel pump experience which I believe is valid for the 2nd gen 1100 Sport-i] :huh2:
